Augh!!! I hate this thing!! - Defender Source
Old June 23rd, 2015, 04:59 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Fk fk fk fk fking damn hell is this thing welded on???
Drilled out the grub screw, hacksawn pieces off and the damn adaptor still will not let go of the shaft. Damn it to hell!
Old June 23rd, 2015, 05:03 PM
Talleyrand's Avatar
Talleyrand
Update, finally got it off but like a complete idiot I have drilled into the shaft itself. :facepalm
Old June 23rd, 2015, 05:08 PM
My issue was the grub screw, but when I took a grinder to the little grub screw, it tore it to pieces before I barely even touched it and the whole thing released from the shaft. I'm assuming it heated it up pretty good in a short amount of time, and may have freed it from the shaft a little. Before that it'd broken an allen wrench and a small drill bit haha.
Old June 23rd, 2015, 05:16 PM
Talleyrand's Avatar
Talleyrand
Seriously, where do they find the engineers who came up with this design?? The grub screw will never let go and the thing will rust itself into place and the stoopid splines will wear out (and that too what a crazy way to attach wipers!!) until your wipers are falling off in the middle off a downpour on the highway. At night.
Same engineer also clearly designed the clip system to keep the window winder handles on their shafts.
Old June 23rd, 2015, 05:27 PM
you installed them just in time before this storm at least!
Old June 23rd, 2015, 05:55 PM
Departing90
Sasha
95 D90
You are way behind the times! The same engineer started working for jaguar shortly afterward and designed the engine in the xf. They have major irreparabler overheating and cracked block issues. Think porsche 911 block. Last I heard as of 3 months ago the going rate on a used xf engine with 15k was 22k. A shop in the OC purchased it and noticed the casing on the hydraulic tensioner was scratched. Wanting everything to look perfect for his client he swapped it with the one from the old engine and neglected to re pressurize it , a 5 hour job and promptly blew up the new engine!
Old June 23rd, 2015, 06:13 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
That same 'designer' that spent all those years ONLY at college without ever using a spanner in anger (nor even knowing what a spanner was) has come up with such engineering marvels as that(and more) ...........Let alone the suits that approved it.......
We are doomed........
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old June 23rd, 2015, 06:45 PM
Talleyrand's Avatar
Talleyrand
Un-fing believable. This was what the other one took to get off ...
Old June 23rd, 2015, 06:46 PM
Do you have a replacement? I think I might have one in my tool box at work if you need it.
Old June 23rd, 2015, 06:52 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Same story over here. I had to angle grind two slits in mine then split them off with a chisel. Will be slathering them in anti-seize
Old June 23rd, 2015, 07:24 PM
gwmckee
George
1994 NAS D90 #1919
Here's what I did...
Same issue. How ironi that the wipers flopped all over the place but the damn collets wouldn't come free of the posts!!! My dad had a small puller that I was able to rig up after drilling out the set screws. they sure put up a hell of a fight. I was able to re-tap the threads, wire wheel and paint them and get new set screws from ACE. They are like brand new.
Let me know if you want them.
Old June 23rd, 2015, 07:38 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
After getting angry trying to get the first one off I bought new boxes and ferrules from RDS when George was still running it. Well worth the pain of taking the dash apart to fit the boxes so as not to deal with the original pieces!
Old June 23rd, 2015, 07:47 PM
dendrite's Avatar
dendrite
97/D90 #147
So, what would one do proactively to prevent this chaos?
Old June 23rd, 2015, 07:52 PM
Talleyrand's Avatar
Talleyrand
Good to know I have company in the suffering LOL. I bought replacement adaptors from Rovers North, they are pretty cheap but the same bloody grub screw design. Yeah I have put lots of grease on the new ones now. But yes the real answer is to take apart the dash, remove the old wiper motor assemblies and replace with the newer ones used in Pumas. Those use a different, more sensible method to attach the wipers: a nut to screw down onto the threaded end of the shaft. Just imagine! Only sixty years to reach that amazing step forward ...
Old June 23rd, 2015, 08:04 PM
Talleyrand's Avatar
Talleyrand
BTW thanks guys for offering the parts. I had ordered everything ahead of time before attacking the project. At least I thought I had everything. I was missing the following special LR tools:
AMR83849FU Suspension of Disbelief Assy
ALF94737WTF Infinite Patience with Zen adaptor
Old June 23rd, 2015, 08:06 PM
This.
Name:	defender oil cooler line fire.jpg
Old June 23rd, 2015, 08:13 PM
I was missing the following special LR tools: AMR83849FU Suspension of Disbelief Assy ALF94737WTF Infinite Patience with Zen adaptor
LOL - post of the day
Old June 23rd, 2015, 08:22 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
X2...
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old June 23rd, 2015, 09:40 PM
BlackField's Avatar
BlackField
Oscar
D110
I ditched the set screws and used stainless socket head screws M4x 10mm, I think I might of used 15mm, either way screw you set screws.
Old June 23rd, 2015, 09:41 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
LOL
Those tools apply to every model and year
Rent my
One thing I hate about McMastercarr Neil McCauley Misc. Chit-Chat 12 December 15th, 2011 10:23 PM
hate to put a jeep part on a land rover mattdh Misc. Chit-Chat 20 November 11th, 2005 08:58 PM
Do the D90 gods hate me!? WCURoverD90 Misc. Chit-Chat 35 March 3rd, 2005 12:10 PM
"Compromise" tires...hate this... DiscoDino Defender Technical Discussions 6 December 27th, 2004 03:50 AM
People who hate the H2 jgoodyear Misc. Chit-Chat 26 December 14th, 2004 02:00 AM
