Attaching License Plate on NAS 90 SW - Defender Source
Old June 2nd, 2015, 08:23 PM
dendrite's Avatar
dendrite
97/D90 #147
What is the best way to attach a rear US license plate? Obviously the existing holes don't match up, and my preference is not to drill holes. Is there an adapter bracket that would utilize the existing holes?
Here is the application:
Old June 2nd, 2015, 08:32 PM
Originally Posted by dendrite View Post
What is the best way to attach a rear US license plate? Obviously the existing holes don't match up, and my preference is not to drill holes. Is there an adapter bracket that would utilize the existing holes? Here is the application:
Make a plate that matches the holes on your truck and has standard US license plate mounts.
Old June 2nd, 2015, 08:34 PM
drill your plate. Why don't your holes match up? There will be bigger issues than this.
curry's Avatar
curry
brandon curry
Series 1 and 110.
I just drilled a hole in my license plate
Old June 2nd, 2015, 08:35 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Easier then that even. Just drill holes in the plate to match up to the holes on your truck then go to the auto store and get yourself some plastic license screws, just ask the salesperson where they are at. No cop is going to gig you for drilling holes in your plate.
What Curry and Josh just said.
Old June 2nd, 2015, 08:44 PM
dendrite's Avatar
dendrite
97/D90 #147
That was fast!
I certainly don't mind drilling holes in the L Plate, however the two holes with the al clips would still be hanging below the L plate. I could even industrial velcro the damn plate on, I was just looking for a more finished look. Something worthy of the Defender moniker!
Old June 2nd, 2015, 08:51 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Industrial double sided tape is what they use the UK to affix the plates...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old June 3rd, 2015, 11:21 AM
dendrite's Avatar
dendrite
97/D90 #147
Yeah, that might be the best solution, however I'll have to be somewhat creative in covering up the existing brackets and holes. I know there is an issue with the latest ben 4Runner where the plate is held so closely to the pain that it never dries out and will start to rust through the pain. The solution was to space the bracket out with some rubber washers.
Just seems like a business opportunity in making a bracket that adapts euro/British hole pattern to US plate pattern, but I couldn't find one, and I'm not that skilled to make one.
Old June 3rd, 2015, 11:30 AM
Is this a Dubai and/or Japan spec 1997 Defender 90? I'm assuming that's why they don't line up?
Remove the AL clips maybe?
Old June 3rd, 2015, 11:37 AM
dendrite's Avatar
dendrite
97/D90 #147
If I'm not mistaken, its a NAS/Japan spec. (is that possible)? The build sheet has some Japan codes, but there is a NAS label on the frame.
Old June 3rd, 2015, 11:39 AM
Then it's Japan Spec. Slightly different than NAS. Makes more sense now.
Old June 3rd, 2015, 12:30 PM
Factory is four rivnuts and you should never use metal screws, use plastic ones (I was so mad getting the plate off my Defender when the bolts seized in the rivnuts).
So, if it were me, and the holes will be covered by the new plates, I would have no issues drilling and installing rivnuts per factory.
Old June 4th, 2015, 09:02 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I don't like having the plate right mounted right on the body, crap always seems to get in between, traps moisture, etc.
Couple options I've used:
-Cheapo plastic universal mount from NAPA, AZ, etc. The one with 50 different hols and slots to fit anything. Some have drain holes, still catches some dirt.
-My favorite; rear plate bracket from a 2000's SAAB 93, the galvy metal one. Available used & cheap form many sources. Probably the best "universal" one I've found, keeps the plate ~1/2" off the body. Have one on my Series, Triumph...
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old June 4th, 2015, 11:49 AM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
Just throwing my 2 cents worth in. What I did was reinstalled 1/4-20 nutserts, used stainless button head screws(allenhead), and used o-rings between the plate and the body. Sealed the hole and screw just fine. Keeps the plate away from body and easy enough to wash out.
Old June 4th, 2015, 12:13 PM
dendrite's Avatar
dendrite
97/D90 #147
Thanks, just the type of info I was looking for!
Here is one I found on Fleabay and another, although they don't exactly match the description you gave.
And from a vendor: Bracket
Are any of these what you were referring to?
------ Follow up post added June 4th, 2015 12:20 PM ------
That's a great way to do it if the holes line up, however since the US plate is shorter in height, it will still leave 2 holes exposed, like where the aluminum clips are in my photo above. I'm guessing because it's a Japan Spec. Maybe I'm missing something (synapse) here, but if you have a picture....
Old June 4th, 2015, 12:35 PM
cascade90's Avatar
cascade90
Mason Worley
No lic. plate brackets for me. I can barely tolerate the plate, much less a bracket. If I was in your shoes I think I would mount it where you want, cover as many holes as you can, maybe use my little method and plug the the other holes. Simple and clean. Sorry for the long winded sentence.
Old June 4th, 2015, 01:08 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
This is how I mounted mine....
Old June 4th, 2015, 01:47 PM
cascade90's Avatar
cascade90
Mason Worley
That works. Wish I could get my hands on big 'ol plate for the wall.
Old June 4th, 2015, 02:51 PM
Chris B
72 + D1 drivetrain =?
Is that legal without a light? -Jeff
Nope.
Old June 4th, 2015, 03:44 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
-Jeff
I need to add a light to it to make it legal...just recently mounted it...
BTW...I ordered new rear and front UK plates from a company (have not mounted them yet, but look fantastic)...not too expensive either...Note that the black rectangle actually has the same stars and GB as the front plate but the flash blacked it out...
90, ac, license plate, nas
Attaching this thing RiftRover Defender Technical Discussions 4 April 25th, 2015 12:59 AM
Bulkhead VIN plate and 4WD plate and tow plate o2batsea Series Technical Discussions 3 July 16th, 2013 02:12 PM
Attaching Bimini Top 1sttimer Defender Technical Discussions 9 August 11th, 2010 04:59 PM
Attaching things..... sundogcwolfe Defender Technical Discussions 1 June 30th, 2010 09:45 AM
Attaching a cut winch line Sam_rover Defender Technical Discussions 9 April 17th, 2007 04:00 PM
