Attaching a cut winch line - Defender Source
Old April 16th, 2007, 12:14 PM
Sam_rover
Sam
I need help with figuering out how to attach a used winch line to a used winch which I bought from different people. I have a Warn 8000, and a winch line which is cut. Is there an easy way of attaching this to the winch? I was expecting a connector of some sort on the end of the line to attach it to the winch but it looks like the line was cut. How does one go about doing this?
Sam
Old April 16th, 2007, 01:07 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
there should be a bolt hole in the drum for a bolt & steel retainer
Old April 16th, 2007, 01:13 PM
Sam_rover
Sam
Hi Peter,
I do have the screw hole in the drum, but nothing on the line that I can use to attach it there. I need help figuering out what i need to attach to the line so I can connect it to the drum.
Sam
Old April 16th, 2007, 02:06 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Take the line to your hardware store and the screw from your wench as well. describe what you are trying to do. They will be able to sync you up with a clamp. The line only needs to be held in place until you get your first layer of line around the drum. BTW, never let out your line further than the last layer when wenching anyway.
Clay
Old April 16th, 2007, 02:16 PM
Sam_rover
Sam
Thanks Clay. I'll give that a try, appreciate it.
Sam
Old April 16th, 2007, 02:49 PM
outfield
Steve
1995 D-90 SW #351
Sam,
If you can't find a terminal to put onto the end of your wire rope call WARN and they will mail one to you. The terminal will then need to be pressed onto the end of the rope.
Old April 16th, 2007, 07:10 PM
Sam_rover
Sam
Steve,
I emailed Warn, they gave me a part number. I called my local distributor and they told me that part is not what I need for the cable... so just going to try Clay's method first.
Sam
Old April 16th, 2007, 07:16 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
Originally Posted by Sam_rover
Steve,
Sam
I`d listen to Warn, personally. They do, you know.... make the stuff in the first place.
Old April 17th, 2007, 02:59 PM
outfield
Steve
1995 D-90 SW #351
Sam,
PM sent
Old April 17th, 2007, 05:00 PM
You can buy a Line Lock which is a little piece of nylon material that you can thread and keep 5 wraps of the line on the winch drum. BWOverland sold them. They were originally designed by Dynaflex. They work very well and keep you line secure on the drum.
I had a similar issue connecting my synthetic line on my Superwinch Husky 10. It works very well and is like $6.00
ac, winch
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
steel winch line rvrsrvc For Sale - Parts 0 February 15th, 2005 12:01 PM
synthetic winch line good or bad ripp2002 Defender Technical Discussions 1 January 18th, 2005 07:28 PM
Steel winch line NIB sheki For Sale - Parts 0 September 30th, 2004 05:43 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
