Atlantic Brit Tire Carrier install instructions - Defender Source
Old July 26th, 2010, 06:44 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
anyone have them? didn't come with kit. Keep forgetting to call them in the am (pac time)
Old July 26th, 2010, 11:33 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
They don't have any. Just use a steel punch or old screw driver and knock them out. It can be a bit of a PITA. Don't be afraid to give them a good whack to get them out. A bench vice works nice to press them in. I bit of grease will help. Really a not a bad job. Best of luck
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old July 27th, 2010, 01:34 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Hmmm. Scott - I really wish I know what I was knocking out.
This is the whole swing-away tire carrier to SW tailgate kit. Misc plates with holes. Couple bags of nuts and bolts. Replacing the door mounted tire carrier.....
Old July 27th, 2010, 01:43 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I think he was talking about the bushings.
Wish I had a copy... I did install a similar one on a 90 a while back. The only tricky thing I remember is to make sure the load is on the body no the door.
Defiantly make an extra bracket to reinforce the tub on the inside (think L ). They can really f-up your body if you put a heavy tire on it.
If you want a hand give me a ring.
Old July 27th, 2010, 01:59 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Hey Steve -
I'm going to e-mail you seperately about it. Been up in the Sierras all last week. Figured I'd come take a look at yours - but NO!, you have an Ambo now..... Maybe get you to give me a road map of what goes where. And yes, your body cracks were high in my mind when I bought it, but doubt I'll ever see the miles and roads you have with yours.
Old July 27th, 2010, 02:16 PM
roverx's Avatar
roverx
Scott Preston
Hey Tony,
Send me an email roverx@comcast.net I think I have a few pictures of the last one I did.
Scott Preston
Old July 28th, 2010, 03:12 PM
16kpsi's Avatar
16kpsi
Tony Lawson
OK, so this is what I have. Scott sent me a pic of his ST tailgate which helps to get basic layout (thanks again) - but I have a few..different...pieces.
Obviously, no plug/socket arrangement that hold the door open as per the ST's
Mine is for an SW - which I'm sure is the key to the big, rectangular plate on the left. But where does it go? Doesn't match any of the bolt patterns of the hinge pieces. I had thought it would mount to the door and take the left hinge piece, but no pattern match. Or do I drill in place? I assume the smaller brackets on the right are part of the High Lift mount - but anyone with a detail pictuire would be a big help. Hinges brackets that mount to the rear tub are larger than the ST parts, but that can only be a good thing....
Old July 28th, 2010, 04:30 PM
D90user's Avatar
D90user
steve
Does the plate fit inside the door between the steel vertical braces? Odd holes though...
That is my best guess...
Old July 28th, 2010, 04:50 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I have an email into the guys who made it lets see if they get back to us.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 28th, 2010, 05:04 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Eric
indeed
Old July 28th, 2010, 09:02 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Eric,
this write up Chris posted appears to be very similar to what I have. Not sure about you but hope it helps (it's all here if you can find it!)
http://www.defendersource.com/misc/wva_carrier.pdf
Old July 29th, 2010, 08:55 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Yep that is the correct one same company.
Eric Riston
Old July 29th, 2010, 10:26 AM
I am in the process of buying a carrier from them at the moment. I get a much better response when I phone up.
Old July 29th, 2010, 12:38 PM
16kpsi's Avatar
16kpsi
Tony Lawson
WHAT? the brits don't respond to e-mail? the horror.
carrier, tire, tire carrier
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
Bummed about tire carrier jdb3760 Defender Technical Discussions 12 January 27th, 2005 05:48 PM
