ATF Leak underneath Radiator - Defender Source
Old October 7th, 2006, 09:52 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I have what appears to be automatic transmission fluid leaking at the radiator. It is red fluid and its coming from the passenger side fitting on the very bottom of the radiator. Is there an "O" ring that needs to be replaced in there? I am trying to find out how to fix before I make a mess. It is also a PITA to get to the fitting. I have had someone tell me that "crows feet" is the way to get to it, but I thought I'd ask here too.
Thanks guys.
Old October 7th, 2006, 10:39 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Sounds to me like you are leaking from your power steering resevoir unless you have installed a transmission cooler. Unless there is something drastically different on 97's that I am not aware of, the only thing going through your radiator is engine oil and coolant.
Old October 7th, 2006, 12:00 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
pull the rad shroud it should be right there
Old October 7th, 2006, 02:10 PM
I had the same problem a few years back... It was the Trans cooler that had developed a leak. If this is it, you have two options, buy another factory LR one for $200+ or buy an aftermarket one for $40.00.
Old January 16th, 2007, 10:25 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I found the problem. Pinhole leak at fitting on the trans cooler. Ordered a new one and should be good to go.
Right on about removing the front radiator shroud behind the grill. It was really easy to get to it by doing this.
radiator
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Leak in the radiator bomilcar Defender Technical Discussions 9 March 27th, 2007 06:58 AM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
