ATC/ATO Fuses - Defender Source
Old September 13th, 2004, 01:01 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
ATC/ATO Fuses
Does anyone know if you can get an ATC/ATO fuse for 1.5 Amps? I can only find them for the AGC (glass) fuses. Thanks.
DJ
Old September 13th, 2004, 04:19 PM
Best I could find was 3 amps, what are you putting a 1.5 amp fuse on?
Old September 13th, 2004, 05:17 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
My GPS. I removed the in-line AGC fuse (1.5 Amps) so that I could run the power supply for my GPs through my accessory fuse panel. It looks as though 3 Amps is as low as an ATC fuse will go.
Thanks for looking Mike.
DJ
Fuses Keep Blowing boshea Defender Technical Discussions 4 December 13th, 2005 08:21 AM
Wiring to unused/spare fuses Trevor Tarr Defender Technical Discussions 3 January 21st, 2005 05:27 PM
97 D-90 SW blowing fuel pump fuses intermittantly BarryO Defender Technical Discussions 9 July 20th, 2004 03:07 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
