Assistance with Fresh Air Vent Fan - Defender Source
Old November 9th, 2008, 04:11 PM
JRW's Avatar
JRW
94 D90 ST #1247
Looking for some guidance...
With winter approaching, I am trying to get the heater/fresh air ventilation working on my 94 ST. When ever I put the lever into the fan mode, I am blowing a fuse. I pulled the cover off the RH wing and reached in to see if the fan would turn. Unfortunately, I am barely able to turn the fan by hand. I assume this is my problem...
How difficult is it to replace the fan unit on the heater box?
Thanks!
Old November 17th, 2008, 12:01 AM
JRW's Avatar
JRW
94 D90 ST #1247
Any thoughts???
Really appreciate any feedback.
Old November 17th, 2008, 01:03 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi John, its an easy enough job, only bolts hold the fan to the heater housing, however you have to remove the heater housing to get at it.
remove heater hoses, remove control cables, undo 5 bolts holding heater to bulkhead and you should be able to wiggle it out.
while its out it may be a good idea to drill out the rivets around the top of the heater and check the matrix, i have packed the sides of mine with dense foam to stop the air getting around the sides of the matrix.
the original foam had broken up and allowed the matrix to rattle about.
a tip for you is to drill a small drain hold in the bottom of the fan chamber to allow any water to drain out.
Old November 17th, 2008, 03:31 PM
JRW's Avatar
JRW
94 D90 ST #1247
Thanks!
fan
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Fresh (Cold) Air Intake D-90 CDeWan Defender Technical Discussions 8 November 4th, 2008 02:24 PM
Air Vent Lever Control - hi/low Flagg Defender Technical Discussions 23 November 18th, 2006 02:08 AM
Front Air Vent Lever Broke...Argh! boshea Defender Technical Discussions 5 February 15th, 2006 08:08 PM
