Ashcroft underdrive - Defender Source
Old November 3rd, 2005, 06:26 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Ashcroft underdrive
Anyone running the Ashcroft underdrive unit?
Or do you know of anyone who is using one? Are they noisy and do they hold up well?
Old November 3rd, 2005, 08:19 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I know someone using one. It is not noisy and seems to hold up just fine although he just finished a frame off resto 3-4 months ago.
Old November 3rd, 2005, 09:42 PM
Randy I talked with Dave at Ashcroft about these a little, and I'm sure he'll chime in here as he checks in on the forum now and then. But They are I belive near the same as the older ones from a few years ago with only a few mods to make them better. You know what happend with my T-case from them, I am very happy with the part and their service, I would not hesitate to buy another product from them. Noah, the guy who bought ECR 3 has an original underdrive on his 90, it worked well the few times I saw it used and ran quiet.
Old November 4th, 2005, 12:37 AM
pendy's Avatar
pendy
jim pendleton
89'd90
The underdrive rocks.
legend in my own mind
Old November 4th, 2005, 06:35 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Do you guys know what kind of shifter and linkage works well. Seems like I read somewhere that a Classic Rangie lever of some kind works. Maybe it was the diff lock lever?
Thanks for the input guys!!!
Old November 4th, 2005, 10:48 PM
pendy's Avatar
pendy
jim pendleton
89'd90
If you buy one I will help you with the linkeage.
JP
Old November 4th, 2005, 10:55 PM
Monkeyboy
Guest
Posts: n/a
Hey P -
Is this the underdrive that lives in the green 90 from St Louis?
Old November 5th, 2005, 08:30 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Thanks Jim, I am feeling the need for one. I'll call you if I go through with it.
Old November 7th, 2005, 03:23 PM
ashtrans
Dave Ashcroft
Hi,
the last batch are the best ones we have made, they have all worked OK but the design evolves each time we make them,
we fitted one a few weeks ago and used the Disco II cable operated high/low linkage to actuate it, worked very well,
Dave
Dave Ashcroft
Old November 7th, 2005, 04:10 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Dave, Do you have any overdrives in the works? I would rater have an overdrive then change my t-case gears
Legend in My Own Mind.
Old November 7th, 2005, 04:21 PM
What's wrong with these?
Old November 7th, 2005, 09:12 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Thanks Dave, I'll contact you.
Maxi-drive t-case gears vs. Ashcroft Underdrive cdb Defender Technical Discussions 7 November 4th, 2007 03:42 PM
Ashcroft Underdrive Barnett Childress For Sale - Parts 1 November 16th, 2006 07:02 PM
The Ashcroft Underdrive is Back Mike Hippert Misc. Chit-Chat 1 June 9th, 2005 09:12 PM
Underdrive Jase Wanted 2 January 24th, 2005 08:19 PM
230 underdrive boxerhips Wanted 0 June 5th, 2004 12:59 AM
