Ashcroft options? - Defender Source
Old August 8th, 2016, 10:20 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Ashcroft options?
I'm thinking of ordering a Stumpy R380 and a 1.2 lt77 from Ashcroft to replace my lt77 and 1.4.
My question is that which of the options are worth getting.
On the tranny:
they offer 44l or 50j ( I think the 44l is right for the 200tdi)
Heavy duty rear support bearing?
And the higher 5th gear.
On the T/C:
Sleeved casing?
And heavy duty cross pin?
Atb center diff?
Old August 8th, 2016, 10:57 AM
carlosz's Avatar
carlosz
Carlos
I would speak with Dave and ask his opinion based on current powertrain and expectations after swap.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old August 8th, 2016, 11:04 AM
You need to carefully consider the gearing options. What LT77 do you have currently? There are a variety of possibilities and gear ratios. If you have a 0.83 5th and go to 0.77 and 1.2, you are 20% lower in 5th.
What engine? Stock? Souped up? How heavy are you on the off roading?
Old August 8th, 2016, 11:19 AM
Higher 5th and 1.2 sounds miserable on a 200tdi.
I would stick with 1.4 t-case and just replace the trans (and the t-case input gear).
Old August 8th, 2016, 11:24 AM
BullTrout14's Avatar
BullTrout14
1985/Defender 110
I got the higher 5th gear on mine when I replaced it and it dropped the rpms by ~ 400 driving 110-120 kph on the highway would definitely recommend it. That is in a fairly heavy 110 with the 300 tdi.
Old August 8th, 2016, 11:26 AM
speedpin's Avatar
speedpin
Looking ;)
I had 200 tdi, stumpy r380 with HD bearing and higher 5th with 1.4. Get the cross drilled input gear for your 1.4 if its not already . Loved it! The r380 has a different t/c linkage than the lt77. So you can ask to have a used set included as well. Dave was great and shipping took about 3 weeks but that was when they had to build to order. Ask if they have some built in stock, it will be a quicker turn.
Admin: might need to preclear the payment with credit card company, I did not and first try got flagged by fraud department.
~ Semper Fidelis ~
Old August 8th, 2016, 11:41 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
You don't want the 1.2 LT230.
Suggest you go with 1.4 gearing.
RDavisinVA
Old August 8th, 2016, 12:23 PM
Contractor's Avatar
Contractor
Will
1969 IIA
The ratio calculator on their site is quite helpful, I have run tons of different scenarios weighing my options.
Anyway, it's on the bottom of the menu if you have not found it yet.
Old August 8th, 2016, 02:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is that with a 1.4 T/C?
------ Follow up post added August 8th, 2016 03:02 PM ------
I've got the later LT77, with a 1.4
110 crew cab, not overly heavy other than a cage and a winch bumper.
Updated intercooler stock location, but thinker. Fuel turned up a bit, nothing to crazy.
I'm really looking for more on the highway, to cruise at 65 with a little lower revs.
Old August 8th, 2016, 03:08 PM
BullTrout14
1985/Defender 110
Yes, sorry forgot to specify.
Old August 8th, 2016, 03:27 PM
Need the serial number to figure out what you have. Most likely a 0.83 5th gear, though, so the R380 will already be 8% higher at 0.77.
For a 110, you will probably not be happy with 1st gear and the 1.2.
The 1.4 with the extra high 5th (0.73) might be the best choice. You still get stock first, with a 14% higher 5th.
Old August 8th, 2016, 03:44 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Great thanks.
I'm more than a bit clueless with the ratio thing, but is there a way to equate the 8% and the 14% to figure the drop in Rpms in 5th.
Old August 8th, 2016, 04:08 PM
Great thanks.
You can play here: Ashcroft Transmissions - Ratio Calculator
Assuming 32" tires and current 5th is 0.83:1, at 65 mph, 2833 rpm
0.77 and 1.4 = 2625 rpm ( 2833/2625 = 1.08 i.e. 8%)
0.73 and 1.4 = 2496 rpm (1.14, 14%)
0.77 and 1.2 = 2254 rpm (1.26, 26%).
Old August 8th, 2016, 04:24 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks for all that. It's perfect. I'm gonna go out and get my truck up to 65
Old August 8th, 2016, 07:58 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
66mph@2800 rpm
200tdi LT77 (higher gearing, I assume). LT230 1.4 255-85-16s
VDO I set with a electronic tach thingy. Reflective tape and "Lazer"
VDO SPEEDO checked with GPS.
Series T-case w/ Ashcroft 5-spd adapter Kit TDI Guy For Sale - Parts 4 September 4th, 2006 10:25 AM
Ashcroft transfer case upgrade pcarey Defender Technical Discussions 15 November 10th, 2005 02:15 AM
Ashcroft underdrive snuffer Defender Technical Discussions 11 November 7th, 2005 09:12 PM
Great Basin or Ashcroft 4.11 R & P Steve Friedman Wanted 1 July 4th, 2005 10:52 AM
The Ashcroft Underdrive is Back Mike Hippert Misc. Chit-Chat 1 June 9th, 2005 09:12 PM
