Ashcroft Limited slip diff for LT230 - Defender Source
Old June 16th, 2015, 07:56 AM
Spotted this on the Ashcroft site. Haven't decided what I think of it yet, but its always interesting to have options.
Ashcroft Transmissions
Old June 16th, 2015, 11:34 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I've been thinking of getting one. I'm notorious for forgetting to lock my diff at times.
Black Rhino Lives Matter
Old June 16th, 2015, 11:43 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I've fallen into that trap before...
Old June 16th, 2015, 11:46 AM
Always embarrassing when it happens.
Really the big plus of this is for high speed work like racing.
Old June 16th, 2015, 07:18 PM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Or just high speed dirt/gravel roads.
A few of the blokes on AULRO have them and reckon it makes a huge difference in driveability on gravel, just stops the hunting back and forwards of the open centre diff without the inherent understeer of a locked centre diff.
I'm hoping it also eliminates a bit of slop from the t/case, I have one, plus Maxi Drive low range gears going in this week, if I can actually get time in the workshop.
Old June 16th, 2015, 10:56 PM
doktorno
Chris deZ.
1995 Defender SW
Had one in my RRC and would like to have one in the D90.
Old June 18th, 2015, 11:11 AM
Blake's Avatar
Blake
Blake
1997 90 Wolf
I was curious about these myself but have never cone across an installation manual. Is there much to putting one in besides refreshing the front and rear output seal/bearings and dropping this in - or is there some shimming and such required also?
Old June 18th, 2015, 11:51 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You must have one of those weird D2's without LOW range.
Old June 18th, 2015, 12:29 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That WAS low range ya nerd, just wasn't center locked
Old June 18th, 2015, 12:55 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
He had it mixed up with a Fleelander.
Old June 18th, 2015, 02:27 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Man that thing sounds anemic!
How many gerbils you got in there?
Old June 18th, 2015, 02:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yeah, I love the tdi, so much better in low range
Old June 18th, 2015, 02:40 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
No, I meant that your truck specifically sounds anemic compared to mine!
Old June 18th, 2015, 02:54 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I'd be more likely to get the upgraded cross shaft than the limited slip. -Jeff
While the case is open, what's to say you can't do both?
Old June 18th, 2015, 03:16 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
It doesn't say what type of lsd it is, but I wouldn't think it uses the same guts. -Jeff
It works on the same concept as a Trutrac. And you still have your difflock.
I've been contemplating getting one.
Old June 18th, 2015, 03:35 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I want one for running on snow-covered roads. My 80 series cruiser has a viscous center diff (similar setup) and it is an animal in the snow. I always found that the range rovers with the BW case performed better on snowpack than LT230 equipped discos, and I suspect it's the center diff.
The cruiser has a selectable center diff lock and engaging it (instead of leaving it limited slip) makes it handle way worse in the snow.
JL
Old June 18th, 2015, 04:17 PM
It is a Torsen diff. No cross pins. Much stronger than stock.
Old June 18th, 2015, 04:50 PM
oilburner's Avatar
oilburner
JL
large pile of parts
There is a thread on Pirate4x4 where Buck installed one in his race car (LS based V8 space frame lunar lander buggy racing thing). That guy could bend a crowbar in a sandbox and he hasn't broken it yet.
JL
Old June 18th, 2015, 05:29 PM
Didn't Quaife make one for the lt230 at some point? -Jeff
Yes quaife make one as well. It is two or three times the cost.
Old June 20th, 2015, 09:10 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
The Quaife ATB sometimes needs shimming to cure excess end float, something Ashcrofts ATB doesn't seem to need.
For a unit that uses the same design as the Quaife but is so much cheaper, it's a bit of a no-brainer, and that goes for the final drive ATB's too.
lt230
Limited Slip or Locking Differential petminded Defender Technical Discussions 70 January 1st, 2015 12:35 PM
LT230 question vs Ashcroft "Master" rebuild kit o2batsea Defender Technical Discussions 2 December 28th, 2011 10:00 PM
Can anyone confirm that a 95 Disco 1 came with a rear limited slip CDeWan Defender Technical Discussions 7 January 22nd, 2009 03:49 PM
Truetrac Limited slip Anyone want to let one go? CDeWan Wanted 10 November 6th, 2008 06:53 PM
