Ashcroft Center Console Instructions? - Defender Source
Old April 3rd, 2008, 11:40 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Does anyone have instructions on how to assemble and install the Ashcroft Automatic Center Console? Or am I supposed to just figure it out myself since no instructions were included with mine.
Gary
Old April 4th, 2008, 12:23 AM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Come look at mine Gary. Should be the same.
Old April 4th, 2008, 03:29 AM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
I took my center console out a couple years ago to put Dynamat on the inside. The hardest part was figuring out how the get the auto shifter off! The only attaching bolts for the console are at the very back under the lid; other than that the console just 'sits' on the floor. Pull out the tray so you have access the the metal frame and it bolts down to the floor. The NAS autos I believe have pre-tapped/threaded nuts in the floor to accept the bolts. You'll probably just have to start drilling!
There was also one little press-fit button at the very front buy the hood release but its not needed.
Hope that helps.
P~
Old April 4th, 2008, 11:56 AM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Yes, it does help as it answers one of my questions, how is it held down. Some other questions are:
1) What is the reccomeded lid hinge to use?
2) How do you secure the insert into the lid?
3) What is the large square angled piece used for?
4) How does the latch get mounted to the cover?
Hope that helps.
P~
Thanks Mike, I sort of forgot you had one....
Gary
Old April 5th, 2008, 12:12 PM
proulx70's Avatar
proulx70
Paul S.
1)What is the reccomeded lid hinge to use?
The lid hinge is a "piano hinge" that runs the whole width of the lid.
On the factory one, its melted in place. You could use some epoxy. GOOP works really well.
Do you mean the metal piece? That what holds the whole thing to the floor.
You have to make some holes. You could use a soldering gun to melt the hole if you have the flat blad-like tip attachment on the gun. Then it screws together from the underside.
I'll try to take some reference pictures for you in the next day or two.
P~
Old April 7th, 2008, 01:24 AM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Looks like I have it pretty much figured out. Thanks for the info guys, it helped!
Gary
Old April 7th, 2008, 04:28 PM
ashtrans
Dave Ashcroft
Hi,
you must have bought it a while ago as we have been supplying them assembled for about 18 months now,
we now charge a bit more and only supply them assembled because as you have found out it can be very time consuming, we are building a batch now in the workshop if you would like any photos posted,
let me know,
Dave Ashcroft
Dave Ashcroft
Old April 7th, 2008, 05:29 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Pictures would be great! It would be nice to see what it is supposed to look like as I assemble mine.
Originally Posted by ashtrans
Hi,
let me know,
Dave Ashcroft
Gary
console
FS - LR OEM Center Console w/radio - 1995 jam90 For Sale - Parts 2 January 19th, 2006 11:31 PM
Tuffy Center Console Peter Defender Technical Discussions 0 September 7th, 2004 04:00 PM
Center Console Nobrega Defender Technical Discussions 10 April 29th, 2004 10:29 AM
97 Center Console lobster Wanted 3 March 2nd, 2004 02:13 AM
Cheapest place to buy a tuffy center console JRowe Defender Technical Discussions 3 October 6th, 2003 10:42 PM
