as long as we're talking about oil cooler lines... - Defender Source
Old June 28th, 2012, 08:56 PM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
So I read with interest all the recommendations to change the oil cooler lines, some with illustrations. What I'd like to know is whether the problem is the proximity to the exhaust manifold heat that causes the lines to fail...or the lines WILL fail and the proximity to the exhaust heat causes the fire?
The reason I ask is my oil cooler lines are at least 6-7 inches away from the manifold, and from some of the pictures that have been posted, I've seen several that were much closer.
I plan to replace mine with the Trailhead 4x4 lines, but I am curious as to the source of the problem.
Old June 28th, 2012, 09:02 PM
Main causes of oil cooler line fires from what I've seen are:
1. Procrastination
2. Denial
3. Age - dry rot
4. Location - exhaust
Old June 29th, 2012, 07:51 PM
bikerblock
Kelly Block
1994 D-90 #1138
I just changed mine today, I got a set from Eric at Trailhead. Very easy to do, smaller hands would help. Started bending my old lines back and forth, sure enough one cracked bad enough to leak. I would change yours ASAP if you don't know if they ever have been changed.
Old June 29th, 2012, 08:25 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Look at these items,
http://www.summitracing.com/search/?keyword=dei&RC=100
Especially this item,
http://www.summitracing.com/parts/DEI-010405/
Old June 29th, 2012, 09:05 PM
texrover's Avatar
texrover
Jason
So I'm not up to speed on the oil cooler lines, just the generalities
Is it specific to NAS 90's or 110's as well?
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
200tdi oil cooler lines cabell For Sale - Parts 3 June 18th, 2009 12:24 PM
Rover Accessories oil cooler lines Gore Ranger For Sale - Parts 6 June 25th, 2008 11:39 AM
Oil Cooler lines... yes, again, but take a look ECR Defender Technical Discussions 11 December 31st, 2007 11:41 AM
NEW Genuine Oil Cooler Lines + Heat Sleeve pcscharfe For Sale - Parts 7 September 13th, 2007 09:58 PM
Best price on Oil Cooler Lines? bd90 Defender Technical Discussions 9 May 19th, 2004 10:44 AM
