ARP Main Studs - Defender Source
Old February 29th, 2012, 08:30 PM
Mogly406's Avatar
Mogly406
Jay
'62 IIA 109 coil sprung
ARP Main Studs
Hello - I am rebuilding a Rover 3.9L engine (non-cross bolted version) and purchased an ARP main stud kit. I am getting somewhat mixed messages as to what I should torque these to. In the box, ARP specs say to use their moly lube and torque to 110 lb-ft. This seems like a lot and I have read about problems with stripped threads when torquing to ARP's values. The place I bought the stud kit from says they lube with 30 weight motor oil and torque #1-4 to 75 lb-ft and the rear to 80 lb-ft. This seems more reasonable, but still considerably more than if I just used standard bolts and torqued to the Rover values (which is 52 lb-ft for #1-4 and 66 lb-ft for the rear).
My question is has anyone used these main studs and what lube and torque value did you use? I would especially like to hear from someone who has the stud kit and been running for a while w/o problems
Jay
Old March 1st, 2012, 10:10 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I've used plenty of ARP head stud kits & torqued them to 80 lb ft per ARP, but I've not used main studs. You might try talking to D&D Fabrications. The guy is pretty squared away WRT these motors.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 1st, 2012, 10:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I installed the ARP bolt kit on my 4.6 cross bolted engine a couple years ago (ish). I too was confused, and i still have my emails from Kammy at ARP Sales and Tech and they recommended 80ft-lbs using their lube which is what I did. Everything has been fine.
Old March 1st, 2012, 12:43 PM
Mogly406's Avatar
Mogly406
Jay
Thanks for the responses, it helps a lot. I also just noticed that on RPI's website, they claim to torque the ARP main studs to 90 ft-lb, although they don't comment on what lube they are using.
Old March 1st, 2012, 03:09 PM
I dont build engines but I used regular motor oil on my head studs. I know its a different part of the engine, woudlnt any light oil would be suitable.
Old March 1st, 2012, 03:29 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Short answer is no. Watched one of those episodes from spike TV on weekend mornings. They showed with different lubes such as motor oil vs. (ex.)ARP specified lube and there was something like 10lbs. difference sure it could be found on youtube or spike website.
Old March 1st, 2012, 04:38 PM
You have your anwer
ARP bolts or studs o2batsea Defender Technical Discussions 12 July 10th, 2011 06:18 PM
stainless window studs mattdh Defender Technical Discussions 34 December 9th, 2005 08:19 PM
USED defender window studs on ebay eric_besore For Sale - Parts 10 September 3rd, 2005 01:13 AM
ARP head stud compatibility? Hans Defender Technical Discussions 0 November 12th, 2004 10:37 PM
SS Window Studs? bugula Defender Technical Discussions 6 May 17th, 2004 04:47 PM
