ARP bolts or studs - Defender Source
Old July 8th, 2011, 08:12 AM
ARP bolts or studs
Searched threads and ARP site but still unsure of what to order. Studs or bolts? I guess it's a tossup, but bolts seem to me more convenient. I'm so done with fuggin stretch bolts. At the rate I am going through head gaskets, I can't see $200 for bolts every time I need to replace them.
Old July 8th, 2011, 08:38 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Studs. You can use the old metal head gasket with the studs and up the compression (or retain it).
Matt Browne
Old July 8th, 2011, 09:30 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Sure it is a headgasket issue and not a leaking block or slipped sleeve? I see LOTS or leaking blocks now adays.
Cheers
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 8th, 2011, 09:49 AM
LRover's Avatar
LRover
J. Michael McCaig
You can use earlier non-stretch type head bolts (pre-'95) with either gasket type.
Old July 8th, 2011, 12:54 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Use steel gaskets and non-stretch bolts and be done with it. The composite gaskets and stretch bolts seem to cause more seepage and sludge than the earlier type. I only use the studs if I'm build'n a hotrod motor for a client. If you go with the steel gasket/bolts remember to follow the 'ol school torque seqeunce and pattern and order one extra bolt to take the place of the alternator stud that comes with the steel bolt kit.
Old July 8th, 2011, 01:08 PM
studs seem to be more consistent and they are reusable.
Old July 8th, 2011, 02:09 PM
TS888's Avatar
TS888
Tony Sims
1984 110
I've used both, but I'm not sure I have a preference. If you have the room, studs make it easier to mount the heads. If you are tight on room, studs can make it bloody difficult to pull the heads.
Tony
1984 110 "Smokey" (sold)
Old July 8th, 2011, 04:12 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Like Tony said...studs are a tight fit depending on the application(D2,P38,ect).
Old July 8th, 2011, 06:04 PM
Cheers
Eric
Eric I'm pretty well sure it's not the block since the last time I did the head gaskets it was all fine and dandy. Now it is showing signs of leakage again with the engine pushing a little sweet smelling steam out the tailpipe as it warms up. Once it reaches operating temp it's all good and no odd emissions.
------ Follow up post added July 8th, 2011 06:07 PM ------
Obviously you haven't been near a RRC recently. There is not even enough room to change your mind.
Old July 8th, 2011, 08:11 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Can you use ARP studs on a D2 4.6 ?
- Charles Eames
Old July 8th, 2011, 08:45 PM
yes.
Rover V8s were relatively the same for nearly 30 years, this has nothing to do with using head studs..
Old July 8th, 2011, 08:53 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by rover4x4 View Post
yes
Better than regular bolt kit ?
- Charles Eames
Old July 10th, 2011, 06:18 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
yes.
.....and for the first 20 yrs the metal head gaskets with the 3rd row of bolts were a common failure issue . I definately wouldn't recommend using them with the motors designed for composite gaskets........or using regular bolts with the composite....
Matt Browne
bolts
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
ARP head stud compatibility? Hans Defender Technical Discussions 0 November 12th, 2004 10:37 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
