Are these bolts important? - Defender Source
Old November 19th, 2010, 05:05 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
I found these bolts on the floor by the pedals after a 13 hour drive. Can't figure out where they came from. Anyone recognize them? Are they important?
ID:	33312   Click image for larger version
Old November 19th, 2010, 05:11 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Steering colomn shroud screws. Just screw them back in. Not too important.
Robert Deniro
Old November 20th, 2010, 01:19 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My question is, why do they fall out to begin with? Happened to me as well.
My top steering column shroud was busted so I replaced it. When I used the original screws to screw into the replacement piece they don't go in properly. What's up with that? The plastic screw bosses turned white from forcing the screws in and i wasn't able to get them all the way in from fear of breaking them. Now why would they go ahead and change the screw size for a replacement part that looks identical?
Old November 20th, 2010, 10:10 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
mine too, i wrapped them in a small piece of plastic (for a tighter fit) and reinstalled, haven't fallen out again yet.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 20th, 2010, 11:13 AM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Thanks for the help. 1 went in. The other just kept falling out. Oh well.
Old November 20th, 2010, 11:54 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
thread on the other side might not be perfect, try wrapping the screw with a small piece of electrical tape then install.
~2008 GTI TSI
Old May 22nd, 2011, 06:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I ordered a new top shroud and new screws to go with it but the screws won't go in!
WTF!?
In the 2nd pic you can see how the boss is getting stressed and turning white from me trying to force the screws in. What's going on here? I ordered the screws and shroud from part#'s in the part catalogue. How come they won't fit.
It's driving me crazy. First the old ones fall out. Then the new ones won't go in.
ID:	38988   Click image for larger version
Old May 23rd, 2011, 02:15 PM
WTF!?
Regardless of how accurately you ordered it, they may have shipped you random/wrong screws. Check the threads of the screws vs what came out...shouldn't need to force anything
Old May 23rd, 2011, 02:24 PM
The Dro
Dro
1988 Ninety
use Loctite
rover26c's Avatar
rover26c
Lee
1994 D90 ST
What is the part # of the steering top shroud?
[QUOTE=Manimal;282882]I ordered a new top shroud [QUOTE]
Old May 23rd, 2011, 02:50 PM
you def want the screws in the shroud, I lost mine for a couple years and only would remember they were gone when I drove it. Cowl rattled so bad itd make you crazy, almost as bad as the seat rails.
bolts, import
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Source for long body bolts? 1/2x7.5 inch grade 8 cgalpin Defender Technical Discussions 7 March 12th, 2005 12:59 AM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
