Are front springs handed - Defender Source
Old March 30th, 2010, 01:54 PM
Cmikefly
William Challancin
97 NAS D90
Hi,
I having a problem with my new Terrafirma suspension set up and thought someone may be able to offer some help. The front driver side spring is occasionally rubbing the frame / bump stop bracket during braking and or cornering causing some annoying noises. I have a Bearmach adjustable panhard rod fitted and the spring / frame gap seems about the same on both sides. I have two questions:
1. Are front springs handed? I ask because I recall that they were labeled driver and passenger but donít recall if I had enough common sense to install them backwards for a LHD vehicle.
2. is there a procedure for adjusting the panhard rod? Should the truck be jacked up by the frame or sitting on the ground??? I just adjusted it until the spacing felt about the same, the adjusted the drag link until the steering wheel was centered again.
Thanks for the help.
Attachment: my new Co-driver
William Challancin
Al Ain, United Arab Emirates
1997 NAS D90
2005 110 TD5
Old March 30th, 2010, 03:52 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Did you replace all the bushings when you fitted things? If it is only happening under load that points towards a dynamic part not a static part being the issue and in the front end that would be the bushings for the most part. Are you 100% sure the radius arm nuts are torqued down all the way?
For adjusting it you can do it by building a big square and using it to align the front and rear hubs on one side.
How to Change Front Springs johnpiero Defender Technical Discussions 12 February 1st, 2009 07:56 PM
Expedition Exchange shawnpalmer Misc. Chit-Chat 155 June 4th, 2007 10:56 AM
LR HD Front Springs jimbemotumbo For Sale - Parts 0 July 12th, 2005 02:27 PM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
