Are Defenders heavier on the drivers side? - Page 2 - Defender Source
Old May 22nd, 2008, 06:42 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
If they were sand rails or VW based buggies there are no springs because they use torsion bars inside the front end and in the rear tube. I can't imagine them running using shocks only.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old May 23rd, 2008, 01:22 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Well they are not just shocks, they have adjustable gas pressure too - like Fox. Gas pressure shocks work without springs in the right application since the compressed gas is the spring . Remote reservoirs are better and the shocks can be doubled up to provide greater spring rates if necessary. Single long travel shocks with remote reservoirs running pressures of 300psi are most common for competition.
With Foxes on my Rover the ride height/spring rate can be adjusted when loaded up or when running light for crawling.
"I think you need a little weatherstripping - right here..."
Old May 23rd, 2008, 06:53 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Okay, so lets see these shocks working without springs on anything. There is no shock other than an Airshock that has the ability to hold any relevent amount of weight. Extra Nitrogen in a standard shock does almost nothing other than a minimal affect on dampening. Even then, to get any meaningful difference, you have to add or remove shims to the shock.
And doubling the shocks doesn't make a higher spring rate. In a matter of fact, I am not sure there is even a single part of your post that is accurate. Except for maybe the 300psi comment, I just don't know on that one.
I was really trying to be kind with the whole no springs thing, but come on guys!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Drivers side door trouble UtahD90 Defender Technical Discussions 3 December 7th, 2008 12:50 PM
Puddle on drivers side floor bjf Defender Technical Discussions 17 February 23rd, 2008 10:46 AM
NAS drivers side fender steved90 Wanted 0 August 1st, 2005 04:52 PM
WTB: Driver's Side Side Step dzientek Wanted 0 November 8th, 2004 12:21 PM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
