are catalytic converters interchangeable - Defender Source
Old January 9th, 2014, 12:40 AM
Toughy
95 Yellow ST
So my 95 RRC needs new cats and run about 200 a piece for universal, so my question is are catalytic converters interchangeable between rovers other makes etc if the inlet/outlet diameter is same? Any effect in back pressure? 4-6-8 Cyl matter?
obviously I dont know much about them and looking for the cheapest/best route to fix
thanks guys
Old January 9th, 2014, 12:49 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Yes they are. Most replace with Magnaflow cats at ~$70/side plus install. Search here for the part number.
Old January 9th, 2014, 01:30 AM
Toughy
95 Yellow ST
Thanks down shift, Im in CA so ours are crazy expensive unfortunately.
Think I could make this work
so think this would work? http://sfbay.craigslist.org/sby/pts/4278472493.html
Old January 9th, 2014, 04:18 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Why not just order universal Magnaflow cats of the correct size from someone like Summit Racing? They are not much more than the used one you posted a link to.
Re-tune ecu without catalytic converters Help! bstraw Defender Technical Discussions 0 December 23rd, 2006 10:48 AM
Only one catalytic converter??? opinions?? cbass Defender Technical Discussions 7 August 10th, 2005 10:30 PM
Replacment Catalytic Converter chrisvonc Misc. Chit-Chat 5 May 3rd, 2005 06:22 PM
Catalytic Converters and Muffler OCD90 Defender Technical Discussions 1 January 19th, 2005 01:24 PM
Catalytic Converter needed for 94 D-90 ripp2002 Defender Technical Discussions 9 December 15th, 2004 06:43 PM
