ARB wiring harness question - Defender Source
Old January 20th, 2007, 04:51 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I installed my compressor and am wiring it all up today. My question is where to tap the red-yellow wire from the harness into the ignition? Which wire? This is on a SeriesIII.
Old January 20th, 2007, 09:51 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
You do not need to wire it to the ignition switch, just a wire that is hot when the ignition switch is on.
This works ok, but disengages the locker and compressor when you shut the truck off even with the compressor switch on.
So if you want the locker to help when you change a tire or park on uneven ground, you have to leave the ignition switch on.
I added a dedicated switch to activate the system wired from a constant hot so I can switch the system compressor / locker on anytime.
--Benjamin Franklin
Old January 21st, 2007, 11:33 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Thanks.
wiring
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
Doh! ARB 9000i Mounting question dnewman9 Defender Technical Discussions 14 February 5th, 2004 01:11 PM
