arb switches - where to put - Defender Source
Old January 8th, 2005, 12:22 PM
scoloco's Avatar
scoloco
'94 D90 ST
Folks,
I'm getting ready to install ARBs into my truck. I've got the stuff, but I'm now trying to figure out where the best place to put the switches would be. Anyone got pics of your switches willing to share?
tnx
-scott
Old January 8th, 2005, 03:54 PM
brianbonner
Brian Bonner
1994 Defender 90
no pics, but SG makes a console you put in between the vents of the dash. That is what I used. Check the custom section or the faq. I thik there use to be a picture of where someone else placed theirs. I believe there was a whole write up on installing ARB lockers
Old January 8th, 2005, 05:10 PM
Troys
Troy Smith
1995 D90 SW
I too am trying to figure the best location for the switches. I did a brief search for a photo of the SG bracket you refered to but no luck. Any chance you could post a photo of yours?
Troy
Old January 8th, 2005, 05:22 PM
scoloco's Avatar
scoloco
'94 D90 ST
Thanks Brian. Seen the write up, but alas it is all about the the rear diff. Nothing on the switches.
-scott
Old January 8th, 2005, 10:26 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Rover's Down South sells the switch and radio panels for that location between the vents. These are the switch panels for the SW, where the rear defroster and wiper switches would go. You can just make a plate and mount your switches there. I don't think they are too much, maybe $30 if I remember correctly.
Old January 9th, 2005, 07:34 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
scott,if you come to the pub tue nite you can see where i put mine
Old January 9th, 2005, 02:31 PM
brianbonner
Brian Bonner
1994 Defender 90
Sorry no digital camera. it is a clean install and has room for more switches/guages. It is black plastic. it goes over the top of the area the clock and cigar lighter. it fills the area between the top and bottom of the opening in the dash. I am sure SG could send you a picture.
Another location would be in the piece of dash where the dimmer switch is. there is 2 more cutouts available in that section that comes off seperately.
I also put my compressor under the passenger seat. there is plenty of room there. I have had zero problems with it.
Troy
Old January 9th, 2005, 03:02 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I had a local sheetmetal shop fabricate a box that sits between my console and difflock lever. I installed the switches there. Mine are wired up to light up with the dash lights and they are bright enough that I didn't want them on the dash. They are way brighter than any of my other dash lights. They are ARB switches.
Old January 10th, 2005, 09:25 PM
scoloco's Avatar
scoloco
'94 D90 ST
Talking
Sounds like a bribe to me
switch
Switches...where to put them Stmpede Defender Technical Discussions 7 November 6th, 2008 09:54 PM
Where to mount ARB Locker switches shawnpalmer Defender Technical Discussions 25 August 5th, 2007 09:20 PM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
