ARB Removal Help - Page 4 - Defender Source
Old June 26th, 2012, 04:18 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Since you don't have the truck to check against here is what I would do:
If they have them grab 4 off M12x120 and 4 off M10x120 and washers to fit each size. Make sure each one has at least 2" of threads at the end. More expensive, but cheaper than getting to the truck and finding out you have the wrong size.
When you get to the truck remove a bolt at a time and fit the biggest one that will fit out of the M10/M12 in each hole.
If you end up with 2 x spare M10s then use them for the side bolts (if they have them on a Rockware?) as those are smaller than the vertical ones. They may be a little long but they should fit if there is enough thread on the bolt.
That wrench in my pic above is the 'thin walled' one I bought specially to do these bloody things. I had to buy a set of double ended box wrenches to get it. It's Husky brand from Home Depot I think it was. I use that and the box end of a 19mm Craftsman combination wrench for when they are looser to do them.
Old June 26th, 2012, 04:27 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by rijosho View Post
The bolts that came out of there were Atlas branded class 8.8 17mm and roughly 5 3/8" in length partially threaded, but they were definitely longer than they needed to be.
Josh, there are so many things wrong with your picture that I donít know where to start. We'll let Barry or Neil fill in the blanks....
Old June 26th, 2012, 04:48 PM
Originally Posted by down_shift View Post
Josh, there are so many things wrong with your picture that I don’t know where to start. We'll let Barry or Neil fill in the blanks....
I was handling it with gloves because the hole I had pulled it out of was dirty from years of not being properly cleaned, and the penetrating oil I had used was getting everywhere. It's bigger than it looks in that picture. As you can tell I was really bored.
Old June 26th, 2012, 05:04 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
This is the longest thread (no pun intended) on a bolt that is probably the easiest thing to replace on the truck
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 26th, 2012, 05:05 PM
down_shift's Avatar
down_shift
Russell
Used latex glove, big screw, penetrating oil, crotch shot.
Old June 26th, 2012, 05:09 PM
Haha I know - I was thinking the same thing. I don't try to overcomplicate things I swear.
Old June 26th, 2012, 07:29 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Someone's new signiture quote in 3...2...1...
Old June 27th, 2012, 09:05 AM
Jeff, I bought a digital caliper last night from Amazon since I figured I'll need it for this and later projects, so it should be here next week or so. I'll use the old bolts until I take this bumper back off to get blasted and then put the new ones on.
OK next part of the project is building my own winch fairlead license bracket for under $11 as opposed to the $30+ some of these other places are asking for just putting 4 screws through a license mounting plate.
I bought two Maglite D-Cell flashlight mounting brackets for $5.30 for the pair, and a universal license mounting plate for $5.30. Free Amazon Super Saver shipping, so $10.60 to my door. Pretty easy - just mount the maglite brackets in the holes I marked in red.
Name:	fairlead bracket.jpg
ID:	53550   Click image for larger version
Name:	Maglite bracket 1.jpg
Name:	licent mounting plate holes.jpg
ID:	53552   Click image for larger version
Name:	Maglite bracket.jpg
Old June 27th, 2012, 09:54 AM
You might also consider putting grade8 bolts in your roller fairlead. Under tension those little snap rings have been known to deform, the pin slips, the roller binds, and Rij is not a happy camper.
I have two fairleads at the moment - one that utilizes the huge nuts (from the ARB), and one that has the circlips on it, so I should be all set there
Old June 27th, 2012, 09:57 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I wonder how fast that plate will disappear. Dan had his jacked a couple times. I would think a zip tie would stop this in addition to the clips
Old June 27th, 2012, 10:05 AM
I thought that was his motorcycle plate(s) that was stolen, and they took the entire motorcycle with the plates.
Old June 27th, 2012, 11:09 AM
ini88's Avatar
ini88
Daniel Marcello
Pines swallowed 2 of my plates. And one got stolen. And I don't ride with a plate on the bike.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 27th, 2012, 12:22 PM
tjfslaughter
thomas
Burbon
No plate in bike = ticket
Old June 29th, 2012, 09:32 PM
The saga continues. RockWare came back off to get refinished. New sticker on its way. This time it only took 15 minutes to get everything off. I was going to run it as is for a year, but I figured since I'll be gone for the next week it'd be a good time to get it all done and out of the way.
3 bumpers on this in one week.
I think I'm just going to have it painted semi-gloss instead of PC, although the PC on the ARB was still perfect - even after a few rubs - so I've been thinking about it.
ID:	53708   Click image for larger version
ID:	53710   Click image for larger version
ID:	53712   Click image for larger version
ID:	53714   Click image for larger version
Old June 29th, 2012, 11:07 PM
tjfslaughter
thomas
Burbon
Was quite hot today....
Old July 8th, 2012, 06:16 PM
Bumper went out with Tom's stuff over the weekend and got blasted (pictured). Will be eurethene primed then painted satin or semi-gloss black, and I can pick it up next weekend. Was thinking of having it painted body color beluga black, but decided against it - would have been too shiny.
Old July 8th, 2012, 06:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
Stick with satin. It should come out looking good. Ask for some touch up paint when the shop does it.
Old July 15th, 2012, 10:00 AM
Just about done. Picked it up from paint yesterday. It has some epoxy self-etching primer or something (it's yellow) and semi-gloss paint. The painter gave me the remaining paint and the formula, but I forgot to take a pic of it.
Drover over to Tom's place after the painter, and we turned the "Engage/Free Spool" clutch on the winch to the top, since it used to be mounted feet forward on the ARB and had to be turned to not interfere with the RockWare bumper front, since it mounts feet down. It was a little finnicky to get all of the gears to realign once turned but we finally got it.
Then I installed the Warn bracket for the solenoid, to mount it to the winch. The ARB had a place to mount it to the bumper itself.
Finally we then installed it all back on.
Oh, Tom also tried banging out the front fender from some trees that were on the trail.
ID:	54234   Click image for larger version
ID:	54236   Click image for larger version
ID:	54238   Click image for larger version
ID:	54240   Click image for larger version
ID:	54245   Click image for larger version
ID:	54247   Click image for larger version
ID:	54249   Click image for larger version
ID:	54251   Click image for larger version
Old July 15th, 2012, 11:01 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Looks good Josh!
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB Bull Bar W/winching capabilities? saber6 Misc. Chit-Chat 8 December 8th, 2005 06:24 PM
ARB Bull Bar for 97 D-90 Seriesman Defender Technical Discussions 4 October 4th, 2004 10:00 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
