ARB Recovery Point - Defender Source
Old December 3rd, 2004, 11:09 AM
TurkD90
Nedim Aruz
1995 D90 SW
ARB Recovery Point
I'm bringing my D-90 in this weekend to get an ARB bull bar and warn winch installed. I seen quite a few pics of ARB's with either the 3/4 shackles mounts or the Dixon Bate mounts with the coresponding backing plates...I was wondering if this is something that can be added at a later date (i.e after the bumper is attached to the the frame). Also, is the ARB pre-drilled for such recovery brackets?
P.S. The bar was shipped directly to the shop that is mounting it -- otherwise I'd look for myself
Old December 3rd, 2004, 11:33 AM
It is not drilled for the mounts, And it would be easier to put them on before mounting the bumper, at the same time have them grind off the shackle loops on the bottom of the bumper as they get in the way, then get bent and look like crap.
Old December 3rd, 2004, 10:54 PM
dameek
Dennis Meek
95 D90 #2826 Bought New
ARB Recovery Point
I installed the shackles on my ARB bullbar while is was mounted on the the truck. I installed mine without backing plates. On the backside of the bull bar where the bull bar connects to the frame you will notice that this is welded to the bull bar. I placed my shackles so they spanned this weld joint. This way when pulling on the shackle with a winch, the force is being transferred to the frame and I don't believe it would be possible to bend the bull bar. Just don't mount the recovery points on the outside of this area as you will end up bending something.
Good luck,
Dennis
cover
Shackle Mounting Bracket on rear for recovery point? graves14 Defender Technical Discussions 5 January 31st, 2008 03:27 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB Bull Bar W/winching capabilities? saber6 Misc. Chit-Chat 8 December 8th, 2005 06:24 PM
Rear recovery point souza Defender Technical Discussions 33 September 22nd, 2004 11:41 AM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
