ARB Pushing Oil Out The Solenoid - Defender Source
Old September 26th, 2012, 04:44 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
What's the general consensus on fluid coming out the solenoid? Bad o-rings?
I came across this in my searches:
"Some Salisbury axles were manufactured with poor oil drainage between the axle tubes and the differential housing. This can often result in one of the axle tubes filling up with differential oil while running. In most cases this will result in a blocked air vent which will cause the differential housing to pressurize and expel oil from the axle seals at the wheels or force oil into the air system of the Air Locker, eventually expelling oil at the solenoid valve. This is a design flaw which was corrected by most automakers in the later releases of their axle assemblies. If no lower drainage point is present in the differential housing then it is critical that you modify the housing to include one"
I do have a rear Sals, and I do have a leaking hub. Just wondering if I should pull out the locker to inspect and just leave it alone.
Semper Fi!
Old September 26th, 2012, 04:46 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yes sounds like it may be worth your time. I take it you already checked to make sure the breather isnt clogged?
Old September 26th, 2012, 04:49 PM
Wolf Fabrication
Sterling Archer
'08 D3
Not yet, still getting there...
Semper Fi!
Old September 26th, 2012, 06:15 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Clogged axle breather line caused oil to leak out my rear hubs.
Old September 26th, 2012, 06:22 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would check the breather first but it isn't hard to pull the rear cover on the sals and check inside to see. On a side note....did you install the rear ARB? I have to do one on mine and just haven't gotten around to doing it.
Land Rover 110
Old September 26th, 2012, 06:45 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, just researching what to expect. I did the install on the ARB two years ago. It's not hard with the proper tools.
Semper Fi!
Old September 27th, 2012, 04:24 PM
this is like your fuel line. check the breather first please
Old September 27th, 2012, 04:34 PM
Wolf Fabrication
Sterling Archer
'08 D3
Paleese, like you are ever right.
Semper Fi!
Old September 27th, 2012, 04:42 PM
rarely. but, I like to make a big show of it when I am
I talked with Robert Davis today and he asked how your truck was running. Also wanted to know who made your seat covers.
Old September 27th, 2012, 04:47 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, he emailed me.
Just checked the breather. It's clear and so is the tube.
Now, I am running ARB line as breathers, so perhaps the diameter isn't big enough to let the axle breathe?
I am also running a massive HD diff cover with a fill plug that's pretty high. It's conceivable that I have too much fluid in the diff and it's over pressurized. This all started after I topped it off a few weeks ago. Before that it was fine....
Semper Fi!
Old September 27th, 2012, 05:01 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
If the fill plug is higher than the axle tube this is very likely..
Old September 27th, 2012, 05:04 PM
Interesting. Maybe if the breather line was bigger than the ARB line it would be a "path of least resistance" type situation. I had oil pushing up my ARB lines a few years ago and it was the breather. Another thing you can do is operate the locker and see if you hear air leaking inside the diff. That would be indicative of a seal problem.
Old September 27th, 2012, 05:11 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, fill plug is way higher. I still try to keep the fluid level at the axle tube, but it's not an exact science.
Semper Fi!
Old September 27th, 2012, 05:14 PM
grnrvrs's Avatar
grnrvrs
Paul
88
What's that welded to the RHS of the pumpkin?
1970 SIIA 88, Sold
Old September 27th, 2012, 05:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
Reverse extended bumpstop.
Semper Fi!
Old September 27th, 2012, 06:10 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea my guess is its overflowing especially since it just started happening when you topped it up. The fill plug is super high, what diff pan is that?
Old September 27th, 2012, 06:12 PM
Wolf Fabrication
Sterling Archer
'08 D3
It's a no-name I found on eBay for a Dana 60. It's pretty stout! I think it was about $90 shipped.
Semper Fi!
Old September 27th, 2012, 07:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
x2
Hold your old cover up there and mark height of the fill hole on the new cover.
-Jeff
I know where it should be, but it's not like you can put a dipstick in there. The ring gear is right in the way. I use a zip tie and that seems to work somewhat as a level indicator.
Semper Fi!
Old September 28th, 2012, 07:56 AM
Capt Milks's Avatar
Capt Milks
I put a Poison Spyder diff cover on my sals and had the same problem, no ARB However, but mine was pushing oil out the flange. Dropped the fluid level and problem solved.
Land Rover 110
Old September 28th, 2012, 08:01 AM
Wolf Fabrication
Sterling Archer
'08 D3
That's good to hear.
Semper Fi!
Oil and an ARB compressor amasaback Defender Technical Discussions 12 April 4th, 2006 02:22 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
