ARB problem - Defender Source
Old September 9th, 2005, 11:28 AM
tmore
Tom More
1995 D90
ARB problem
I had an ARB locker installed about 5 months ago. From the start I noticed that I was getting gear oil in my airline.. at first it seemed to be a little mist from actuating the solonoid and I assumed that the oil would work its way out of the system but it hasn't it seems to be getting worse. I checked my beather to make sure it wasn't clogged and it seemed fine and the locker itself seems OK.. I can actuate it and leave it on for over an hour without the compessor kicking on so that makes me think that there isn't a major leak?
Any suggestions?
Tom
Old September 11th, 2005, 07:49 PM
If you haven't seen this
http://www.defendersource.com/forum/...ead.php?t=6103
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
ARB Problem : HELP needed Jay Defender Technical Discussions 5 January 15th, 2006 06:09 PM
ARB Compressor Problem : Need HELP Jay Defender Technical Discussions 5 December 5th, 2005 09:52 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
