ARB M002 install location - Defender Source
Old November 2nd, 2015, 03:35 PM
WG_moots
Wilmer
The darker months are coming and I'd like to upgrade my headlights. I have the ARB M002 loom and would like to get an idea as the best/easiest place to install it in the circuit.
I tried the search button. There is lots of talk on this topic but couldn't find any install details.
Many thanks!
Old November 2nd, 2015, 03:43 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I'm pretty sure I used the driver's side headlamp plug to 'feed' the Headlamp Harness, and the headlamp harness positive was taken from the Alternator Output stud, Negative from the Alternator Bracket..
It was oh, maybe 16 years ago when I did it, and it was a different brand harness, but the idea is pretty much the same for all of them..
~Scott T.
'95 D-90 ST - AA Yellow
Old November 3rd, 2015, 08:30 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
It all depends on where your battery is located in your truck. Mine was under the passenger seat in a ROW truck (right hand drive), and I wired it to the battery directly, and fed the headlamps from the same side.
I bought a "project box" from Radio Shack to house the relays and add a little protection from the elements, and mounted the box to the top of the fender well under the hood.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
ARB IPF M002 Headlamp Relay Harness New SMac For Sale - Parts 6 March 5th, 2015 12:43 PM
Webasto Install Location steinhnj Defender Technical Discussions 44 January 22nd, 2015 11:48 AM
ARB M002 Heavy Duty Wiring Loom Troys Defender Technical Discussions 1 December 15th, 2006 03:55 PM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
