arb lockers working correctly? - Defender Source
Old August 22nd, 2006, 07:45 PM
draaronr's Avatar
draaronr
Here
LR3
so got the lockers in the truck, and she drives fine unlocked, I wanted to make sure they were locking this evening, so i turned on the compressor everything good, hit the rear, good, then hit the front, and started to move the truck forward (was on concrete I know this was bad, but was just moving slowly) it was definitely locking front and rear, but when the front was locked truck pulled to the right for a few feet then evened out, so then I noticed it was hard to turn the wheel left, but right wasn't bad, so I unlocked, and I moved forward and it was still tough to turn right, almost impossible. I just moved the truck back and forth until it finally unwound and let loose. The CDL was not engaged, would it steer fine offroad and this was a pavement symptom, or is something binding, it sounded fine, just felt impossible to turn left, and on pavement I didn't want to force it.
Old August 22nd, 2006, 08:19 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
sound like you still had air pressure on the system....
Old August 22nd, 2006, 09:02 PM
draaronr's Avatar
draaronr
Here
LR3
so the fact it was tough to turn the wheel on the pavement was normal, and it will be fine off pavement?
Old August 22nd, 2006, 10:23 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It will be harder to turn the wheel with the front locked on pavement, and off for that matter. The part that is confusing to me is that it was only hard one way. With a CV, this is unlikely, but not impossible. I would go out and try it again. You are not doing any damage having it all locked up on the pavement. Your drivetrain should be able to just release the tension through a chirp of the tires. You should have a harder time turning the wheel both ways.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 22nd, 2006, 10:38 PM
draaronr's Avatar
draaronr
Here
LR3
I'm not saying it was easier to turn right, but it didn't feel impossible. I will put it in the dirt tomorrow after work and see how it feels, or I will try to get it up on a lift and see what happens.
Old August 22nd, 2006, 10:45 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If it was hard to turn both ways then everything is fine. Lockers do that. Time to add a power assist it sounds like. Welcome to the money-pit hole. Every expensive action, has an equal and opposite expensive reaction.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 23rd, 2006, 11:24 AM
btate
Bryan Tate
d90
You need to go get really stuck, turn them on and see if you are still stuck.
If you are still stuck....report back
Good to see you a few weeks ago
BT
Old August 30th, 2006, 08:54 PM
draaronr's Avatar
draaronr
Here
LR3
tried them out tonight worked like a peach, when you get more money these offroad luxuries sure are nice.
ARB or Detroit Lockers?? pgk Wanted 0 January 24th, 2006 10:06 AM
ARB Lockers.... Can't Wait Any Longer mhansen Misc. Chit-Chat 8 March 21st, 2005 12:44 PM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
ARB lockers @ SG! TwisteD90 Misc. Chit-Chat 2 January 13th, 2004 10:03 PM
ARB air lockers install mhansen Defender Technical Discussions 1 December 29th, 2003 11:38 AM
