ARB Locker Switch upgrade - Defender Source
Old March 13th, 2008, 02:09 PM
JMPDIV82
Gregg O'Neill
97/D90
Talking ARB Locker Switch upgrade
My Front and Rear ARB Locker switches are located between the hand brake and 4x4 gear selector. My wife dove my truck today and accidently hit the rear locker switch without knowing. She never noticed the rear was locked in until she called me to say the tires are making a funny noise around corners... Thankfully she only drove the truck at low speeds to her office approx 1/2 away. Anyway I need to change out the switches for two reasons. First the indicator light on the switch is burned out so unless you are completely aware of the sounds the lockers make when you hit the switch you will never know they are engaged until it too late. Secondly all it takes is a little tap on switch for it to engage......I know the first questions will be; why not relocated the switches? If I do that, I will have two holes in the center console..... So now to my question... I currently have the old switches that I want to change out to the new style.. Can I just simply swap the switches out or is it more involved.
Yea, Yea Pictures.. No time right now... Priorities- I am about to start my religious pilgrimage to Savannah. It's St. Patty's Day.
Old March 13th, 2008, 03:47 PM
At least your priorities are straight. They are carling Contura II switches. just replace them with new ones, and make a guard for them (that's what the military does on most new vehicles). Carling also has nice hole plugs, if you want to relocate.
Old March 13th, 2008, 05:14 PM
I would add a master switch somewhere else... I have yet to do this with mine, but it is in the works. I had that happen with a company that detailed the truck.
Old March 13th, 2008, 05:26 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
try not having the air system charged all the time. Pretty sure someone would notice if the compressor is accidently turned on.
Matt Browne
Old March 13th, 2008, 08:11 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You can get toggle switches that have security guards on them that you have to lift to activate the switch.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 13th, 2008, 08:51 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
I would agree with the thought about not having the system charged all the time. Mine has 3 switches, compressor power (when you turn this one on you know it) and the two locker switches. Thge locker switches don't work until the compressor switch is turned on.
I got your JEEP thing, now it hurts when I pee!!
Old March 14th, 2008, 12:07 AM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
That's what I use. The only drawback is sometimes the dog slides onto the switch and shuts off the lockers at ......... inopportune moments. Otherwise I love them.
Old March 14th, 2008, 01:02 AM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Jim is well worth talking to and has a great selection of Contura switches, rockers and console fittings...
https://www.otrattw.com/S2.htm
Owen
"I think you need a little weatherstripping - right here..."
Old March 14th, 2008, 09:00 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have three switches also. No complaints. Have them mounted left of the clock
switch
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Rear ARB Locker RickM Defender Technical Discussions 4 April 20th, 2005 12:22 PM
spring upgrade for ARB stanman For Sale - Parts 0 February 19th, 2004 11:38 AM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
