ARB locker problem continues - Defender Source
Old March 11th, 2009, 10:31 AM
snurp
Keith Kuboske
94 D90 ST Arles Blue
Thought thecleaking locker problem was sorted out, replaced orings and updated to new plastic one, sealed up and replaced compressor due to massive leaks with a vair system with tank and presuure regulator set on a custom manifold that supplies the locker. Started leaking out of the vent tube on the rear axle again. Locker will lock up and hold due to constant presuure from the tank at 90lbs. But will eventually bleed tank dry and compressor will kick back on. Mech says locker worn out and need to replace it is an older rd56. Do they where out? What else is there to do?
SNURP
94 D90 ST White
02 Disco II
Old March 12th, 2009, 08:18 AM
snurp
Keith Kuboske
found gairlibe Crack in copper Airtube.
94 D90 ST White
02 Disco II
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Rear ARB Locker RickM Defender Technical Discussions 4 April 20th, 2005 12:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
