ARB locker install without air - Defender Source
Old February 14th, 2014, 08:33 PM
I have a new to me front ARB 3rd member thanks to Ron that is waiting on install. Waiting on that ARB was a set of Rovertracks HD shafts and CV's. The catch is I don't have the compressor yet. Can I install the ARB now while waiting to get the compressor, and just cap off the air fitting and run as an open diff without issue?
I've got some other things I want before Expo and would like to get the diff and axles in before the trip, and then install the compressor later in the summer.
Mark Kellgren
KM4BOR
Old February 14th, 2014, 08:41 PM
robertf
Robert F
1995 Discovery
no problem, and if you are using that blue hose there will be some point in your arb ownership where it will be unhooked from a compressor anyway.
I'd test it with shop air before installing to make sure the o-ring is good. I tested mine at 90psi shop air. I think the cut off for the arb compressor is in the low 100s
Old February 14th, 2014, 10:14 PM
Thanks all!
Mark Kellgren
KM4BOR
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Need ARB locker install manual dave_lucas Defender Technical Discussions 13 December 6th, 2006 11:05 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Info needed on Arb air locker. rustydefender Defender Technical Discussions 5 January 9th, 2005 03:46 PM
ARB air lockers install mhansen Defender Technical Discussions 1 December 29th, 2003 11:38 AM
