ARB locker - Defender Source
Old December 1st, 2003, 10:57 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
ARB locker
I'm having a problem with my front locker. Here what's wrong. Every time I engage the front locker the air compressor kicks in and never stops and I also lose my rear locker. Yesterday the front mysteriously locked and it was working perfectly but when I tried to lock again I had no luck. I already replaced the front line but that did not help. Is there a way I can diagnose the problem w/o removing the third member. Any advice is appreciated
World traveler
Old December 1st, 2003, 11:36 PM
Tom Fitzgerald
Tom Fitzgerald
Sounds like a dirty/sticking solenoid. Disassemble and clean plunger, should fix it. You're losing the rear because ALL your pressure is venting out the sticking/stuck solenoid.
Tom
Old December 2nd, 2003, 11:26 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Thanks for the info Tom. I will work on it as soon as I get mt 90 from the dealer and see if that will fix my problem.
Later,
World traveler
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
ARB locker (used) Steve Rupp Wanted 0 July 31st, 2005 11:14 PM
ARB Locker and GBR HD axles James For Sale - Parts 4 July 6th, 2005 02:53 PM
Rear ARB Locker RickM Defender Technical Discussions 4 April 20th, 2005 12:22 PM
