I am attempting to connect IPF LED lights with the ARB Intensity Loom. It comes with its own switch, but I would like to utilize my dash switch instead. I have connected everything else aside from connecting to switch itself and would like instruction/guidance.
1st pic: dash switch with pins 1-5 marked. The 2 larger wires that need to be connected are just to the right (black and black with white stripe)
2nd pic: the wiring diagram that I found on message boards.
PIN 1: earth relay
PIN 2: dash illumination
PIN 3: not used, but joined internally to pin 4
PIN 4: earth dash
PIN 5: live
Essentially, where do I connect/tap the 2 black switch wires in order to turn on the lights? Everything I have seen on message boards have started from a virgin switch, without aforementioned wiring within pins. I don't wanna blow anything up or short circuit anything.
My other option is just to connect as they recommend, but I would be using ARB's switch vs the built in one in the dash.
Thanks in advance!
PIN 1: earth relay
PIN 4: earth dash
PIN 5: live
Thanks in advance!
