ARB Headlight Wiring Harness - Page 3 - Defender Source
Join the Defender Source Community Today
Old May 29th, 2011, 04:12 PM
Antichrist's Avatar
Tom Rowe
Another option is to just get the power for the relays from the stud on the starter solenoid, the same one the battery feeds too. If you're putting the relays in the engine compartment.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 29th, 2011, 04:41 PM
JSBriggs's Avatar
Jeff Briggs
Antarctic Blue Super Sports Wagon
The biggest issues is running full power through the factory switch. It will blow before the fuse will. Once you use the switch to power a relay, ARB or otherwise, and not the lights directly, 99% of your issues go away once you put a fresh switch in.
Old May 30th, 2011, 04:56 AM
TS888's Avatar
Tony Sims
1984 110
Originally Posted by Manimal View Post
TS888, I'm going to follow your advice and upgrade the stock wiring with 12AWG cable. Currently I have it set up so the two headlight circuits go to relays in the fusebox. The headlight switch on the ignition only powers the relays. My aux lights are on a separate relay also I the fusebox and they come on with the high beams. Stock wire is 16AWG, right? How difficult is it to replace the two headlight circuits? Is it necessary to disassemble the dash or can it be done without too much hassle?
Carl, I did all of mine under the "bonnet", never touched the dash. In your case, you need to run wires from the fuse box (and I am assuming this the one over the tunnel, I'm not familiar with NAS trucks so perhaps they have a different fuse box?). You may have to remove part of the dash to get to the harness so you can route the wires out to the lamps.
I used a small "project box" from Maplin (UK version of Radio Shack) to hold the relays and fuses, screwed to the edge of the fender left front fender about 12 inches behind the left headlamp. It's not completely water proof, but short of complete immersion (which would take driving through water deeper than 4 feet, not on my list of things to do), it will keep the bits dry.
The box holds 3 fuses and 3 relays, one each for low, high and aux (planning ahead, I don't have aux lights yet). I took supply from the back of the alternator via 10awg wire that splits to the three fuses and relays. Max load for my headlamps and planned aux lamps is 30 amps, the 10awg is good for at least twice that on a run under 5 feet. I could have taken supply from the engine compartment fuse box, but the alternator was 2 feet closer and it's the same electricity! I made a common ground point on the fender next to the relay box and ran a wire from there to the engine block (I think to the mount bolt for the oil dipstick).
The switch signal for the low and high beam relays is taken from the left headlamp wires from the factory harness -- headlamp plug cut off, factory wires run into project box. The replacement harness is all 14 awg, for the right headlamp it runs along the frame cross member at the lower front of the radiator, in split plastic wire sheath. The factory harness for the right headlamp is just zip-tied out of the way. I used new headlamp plugs so I did not have a wire gauge step down right at the plug.
The supply to each relay is fused. The supply from the relay to the lamps is not fused. Why? My logic -- the run to the lamp is short, well protected, and the lamp bulbs are effectively fuses. In the unlikely event of a short between the relay and the lamp, the worst case is I have to replace a relay, a bulb and a few feet of wire. There's nothing else to burn or melt.
1984 110 "Smokey" (sold)
ht, wiring
ARB wiring harness question KevinNY Defender Technical Discussions 2 January 21st, 2007 11:33 AM
ARB HD wiring harness rover4x4 Defender Technical Discussions 7 December 18th, 2006 12:17 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 11:03 AM
» Defender Registry
Add your Defender
