ARB Differential Lockers - Defender Source
Old January 6th, 2013, 09:21 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
Does anyone know where to get ARB diff lockers set up in NYC? I have the set up in my rear differential but my compressor is not set up.
Old January 7th, 2013, 01:20 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
What exactly do you need done? Do you need the locker installed into the diff carrier or is everything plumbed up and you just need the compressor wired up? What about the switches? are they installed already?
Old January 7th, 2013, 05:51 PM
couga861900
I need the switches and compressor installed. All that is installed are the ARB in the differential. Everything else needs to be installed. Thanks
Old January 7th, 2013, 06:38 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Should be a simple job. run some electrics and airlines. or sell it to me for dirt cheap
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 8th, 2013, 09:06 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
When you say the diff is installed, I'm going to assume whoever installed it also drilled the housing and ran the blue airline? If so, where does the other end of the line dead end? I'm sure there is going to be a lot of opinions on this but where do you want the compressor to sit? I have it under the passenger seat.
Long story short, as ini88 suggested, it's not that difficult but time consuming. There is nobody in the city that I've used before but if you tell them exactly what you want, you could probably take it to the dealer worse comes to worse. Tell them where you want the switches and where you want the compressor and you'd probably be fine. If not, I know a few guys in Jersey that could do it or my race shop in Nyack, NY (25 miles out of the city) could do it. They could use my truck as a template.
Old January 8th, 2013, 09:40 AM
couga861900
Cool. Please Pm me the address.
The lines in my truck is not set up. I brought the 300tdi rear axel from a mate who had the ARB front and rear diff locks. He sold me the rear. The's no line set up. I have the compressor and I would like it under my passenger seat next to the battery. I'm looking for the connectors and lines. I have the blue lines in a box but I would like something stronger. I'm planning to get the MUD UK centre console. When I get it I would like the 2 switches installed there. In the future, I'm planning to get Detroit TRUTRAX (unsure of the spelling) installed in the front. I didn't want air lockers on both diff.
Old January 8th, 2013, 10:13 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
If you already have compressor and other bits, why wouldn't you want an ARB up front as well?
Old January 8th, 2013, 02:28 PM
couga861900
It is better to have 1 diff that us mechanical and the other that are air lockers. I feel that if you have a hole in the line or compressor failure, you would still be able to get out of whatever you're into. If both lockers are down, you're screwed.
Old January 8th, 2013, 02:35 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
keep in mind that you will be driving a truck with an "automatic" locker in the front and selectable in the rear. In certain driving conditions, particularly on the highway in snow, this could lead to some unpredictable situations.
That aside, the air lines are fairly simple to do a trailside/roadside repair on with quick connect fittings. If you are truly that worried about the air lines several companies offer SS line kits or you can put the blue line inside heater hose or similar.
Old January 8th, 2013, 06:35 PM
couga861900
Good advice.
With TruTrack, You haver to step on the brakes several times ti engage them. For example, mash 3 quick times and they are engaged-mash 2 X and they are disengaged.
differential
ARB or Detroit Lockers?? pgk Wanted 0 January 24th, 2006 10:06 AM
ARB Lockers.... Can't Wait Any Longer mhansen Misc. Chit-Chat 8 March 21st, 2005 12:44 PM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
ARB lockers @ SG! TwisteD90 Misc. Chit-Chat 2 January 13th, 2004 10:03 PM
ARB air lockers install mhansen Defender Technical Discussions 1 December 29th, 2003 11:38 AM
