ARB compressor pressure limit switch bad? - Defender Source
Old March 24th, 2009, 11:44 PM
cdb
Clark Bowen
Anyone had an ARB pressure limit switch on their compressor go bad?
I've replaced the relay - still no power to the compressor.
Ran positive and negative wires from the battery to the compressor motor leads and the compressor runs.
I use a LR headlight switch to run the front and rear lockers (first notch runs the rears and the second notch runs the front & rear) and I cannot see from the wiring diagram that it could affect the power to the compressor. I have the older ARB compressor that runs the lockers and will air up your tires if you have the patience of Job. I have the isolation switch in line and it appears to work fine.
It Just stopped working and I leave tomorrow for the Hole in the Rock trail and I'd at least like the rears to work.
Clark
compressor, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
ARB Locker Switch upgrade JMPDIV82 Defender Technical Discussions 8 March 14th, 2008 09:00 AM
ARB solenoid connector and switch? MonLand Defender Technical Discussions 3 January 14th, 2007 11:25 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
