ARB compressor mounting - Defender Source
Old August 12th, 2012, 07:36 PM
AgRover's Avatar
AgRover
Adin
1997 Defender 90 SW Badge #2493
I am considering upgrading my ARB compressor that came with my ARB lockers to the CKMTA12 twin onboard compressor. I want to use it to inflate tires and other things. I have my current ARB compressor mounted under the driver's seat along with a dual batter setup. Will the twin compressor fit there as well?
Old August 12th, 2012, 08:52 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Too big
Have you seen a double compressor in person? I wanted one of these but decided it simply would not fit where I wanted it. Went with the single. Good luck.
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old August 12th, 2012, 08:58 PM
AgRover's Avatar
AgRover
Adin
I haven't seen it in person, but the ARB website says the twin compressor is 4" H x 7.5" L x 10.8" W. It sounds like it may fit. I may have to get my eyes on one to make sure.
Old August 15th, 2012, 12:06 AM
I'd like to see a pic of your dual battery setup with the ARB compressor if you get a minute. I've got my ARB in the same spot but only single battery and was thinking about how to fit moving to dual.
Old August 17th, 2012, 02:06 PM
AgRover's Avatar
AgRover
Adin
Jason, I haven't installed the dual battery setup yet, but I can post pics once the install is done.
Old August 17th, 2012, 02:19 PM
Mine is mounted under the passenger seat. Seems to work well there.
Old August 17th, 2012, 02:23 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Mine as well, best place for it I think.
Old August 17th, 2012, 03:16 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
You would have to be a ninja to fit dual batteries and an ARB compressor - with the solenoids - in one compartment. I need to see some pics.
Semper Fi!
Old August 17th, 2012, 03:37 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Loads of room on the Pass side. Even on a 97 with the stupid ABS ECU stuffed in there as well. Plenty of room for some nice coils of hose as built in 'spares' as well. Plus it's a shorter and more direct run to the front locker so there is less hose in the system to fail. It's only a bit but it helps. If I took the coil out I only need about 18" of the weak blue hose in mine. I have enough coiled to completely replace that section if I need to.
Name:	ARB Mount.jpg
ID:	55940   Click image for larger version
compressor, mount
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB Bull Bar W/winching capabilities? saber6 Misc. Chit-Chat 8 December 8th, 2005 06:24 PM
ARB Bull Bar for 97 D-90 Seriesman Defender Technical Discussions 4 October 4th, 2004 10:00 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
