ARB Compressor Install - Defender Source
Old December 26th, 2004, 01:48 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
IS under the seat in the battery area a good place to put the ARB compressor? I am installing mine there.
Legend in My Own Mind.
Old December 27th, 2004, 12:54 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Randy,
I usually put them under the passenger seat in the toolbox to leave room for a second battery in the battery box.
Rob
Old December 27th, 2004, 06:41 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I wish I could put mine there but I have a gas tank under there...Euro tank is under the pass. seat.
Old December 27th, 2004, 07:48 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
mine is under the front wing, drivers side, just behind the headlights.
Old December 27th, 2004, 11:58 AM
Wolfeie
Townsend Wolfe
'94 D90
Down side to the "under the seat" location is that these things get HOT and there is little cooling air circulation under there. I would expect the excess heat to reduce the service life of the compressor in that location - especially if you use it for airing your tires back up.
I put mine under the drivers (left) side wing mounted to the top of the wheel well. That area is getting crowded now - preoiler, coil, headlight and driving light relays, and the ARB compressor. It's been there for 4 years with no problems
Old April 17th, 2005, 08:45 AM
scoloco's Avatar
scoloco
'94 D90 ST
Does someone with a pax seat arb compressor install have a pic or can tell me how and where the compressor is mounted? From looking I cant lie it down flat behind the jack as the solenoids wont have enough space when the lid goes on (unless I put it up at the front). I am trying to not move the jack (in front left corner of the box). The only other option I can see it to put the bracket against the front or right side of the box (with bolt holes coming into the cab). Mount compressor up/down or left/right?
I looked at Jimmys setup yesterday and am tempted to just put it up in the engine bay behind the left headlight. But then worry about and deal with sprayed water and mud from the fan.
compressor
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB Bull Bar W/winching capabilities? saber6 Misc. Chit-Chat 8 December 8th, 2005 06:24 PM
ARB Bull Bar for 97 D-90 Seriesman Defender Technical Discussions 4 October 4th, 2004 10:00 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
