ARB CKMTP12 Compressor & Tank - Defender Source
Old April 16th, 2014, 02:45 PM
KKilo23's Avatar
KKilo23
Kenny
Any one have experience with this unit?
CKMTP12
Old April 16th, 2014, 02:51 PM
friend has one. hasn't used it much yet, but that compressor is pretty good.
Mark Kellgren
KM4BOR
Old April 16th, 2014, 03:12 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
How big is the air tank on that unit?
Old April 16th, 2014, 03:15 PM
pretty sure it is about 1 gallon.
Mark Kellgren
KM4BOR
Old April 16th, 2014, 06:21 PM
KKilo23's Avatar
KKilo23
Kenny
Yup..
Old April 16th, 2014, 07:45 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
$800??????
------ Follow up post added April 16th, 2014 07:46 PM ------
$800?????
Firemanshort
1980 Stage One 109
Sterling, VA
Old April 16th, 2014, 08:57 PM
Yes expensive. Visor compressors are very hog quality and a much better bang for the buck.
Old April 16th, 2014, 09:26 PM
KKilo23's Avatar
KKilo23
Kenny
Any recommendations?
Old April 16th, 2014, 10:10 PM
co2 tank ?
Old April 16th, 2014, 10:21 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I dont really get that compressor. Its big, heavy, inefficient, expensive, and can't be used as sold for lockers.
Heres the specs I pulled off Amazon.
"Ultra compact twin motor, dual cylinder design makes this the high flowing portable compressor of its size on the market at 6.16 CFM (no load) and 4.65 CFM (at 29 PSI)Integrated aluminum air tank and pressure switch regulates pressure between 135 PSI and 150 PSI which is suited to most air powered toolsMounted in a waterproof carry case constructed from a durable impact resistant polymer; the carry case has convenient compartments for storing the air hose and other compressor accessoriesDucted IP55 sealed brushed DC cooling fan and anodized aluminum motor mounting brackets effectively dissipate heat from the motors, heads and electronics allowing for a 100 percent duty cycle (under room temperature conditions)Kit includes: Water proof case, twin compressor, air tank, canvas organizer, 20 feet air hose, inflator and blow gun"
4.65CFM at 29psi? Thats a weird rating. What is it at 90psi?
Regulates pressure between 135 amd 150? Lockers don't like that high pressure.
It comes in a nice box which is great for transport, but who needs to do that? Having it in a box means you can run it remotely while wheeling for lockers.
I have a Puma 12v compressor. Bought it used for $165 and its been a workhorse for the last two years. Runs my lockers, fills my 315/75's no problem.
I'm currently turning my AC compressor into OBA, mainly just for fun.
Old April 20th, 2014, 01:00 PM
The 400 or 450 models are the high output ones. There are hard mount and portable versions as well as ones with tanks.
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
ARB air lockers w compressor & switches RoverDude For Sale - Parts 3 May 26th, 2013 08:52 PM
ARB compressor & outlets (?) Cube II Defender Technical Discussions 9 December 15th, 2004 03:48 PM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
