ARB carrier bolts backing out - Defender Source
Old April 1st, 2012, 10:34 PM
crobinson
Chris Robinson
97' D1
Pulled the 3rd member today to fix a gear oil leak. When I drained the axle housing there was several metal pieces attached to the magnetic drain plug. When I got the 3rd member out I found the carrier bolts had all backed out. I think the metal pieces come from the locking tabs under the bolts (see pics). So, should I go ahead and have the ARB rebuilt or just loctite the bolts one at a time? I have not bench tested the ARB for leaks yet.
ID:	49787   Click image for larger version
Old April 2nd, 2012, 10:07 AM
Locking tabs are supposed to go over the bolt head, not under the bolts. Who rebuilt that locker?
FYI those bolts and the lock tabs are single use only. You might get away with re-using the bolts if you use red loctite. IIRC that is what is on them when you buy new ones.
Old April 2nd, 2012, 09:29 PM
crobinson
Chris Robinson
97' D1
Got a great deal on a OPEN BOX RD56. Some small parts were missing. Order a new seal kit from ARB. A good friend and I reassemble it. I guess we weren't paying much attention where the locking tabs go.
ac, bolts, carrier
Tire Carrier bolts bjf Defender Technical Discussions 35 January 13th, 2015 01:57 PM
SS Tire Carrier Bolts bjp Defender Technical Discussions 1 April 1st, 2009 12:18 AM
Salisbury Diff Cover Bolts - ARB Diff Cover Shearpin Smaller Projects 4 February 20th, 2008 03:52 PM
Stock Carrier Bolts Joe P Wanted 14 November 7th, 2005 08:22 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
