Aqua Hot - Defender Source
Old May 28th, 2010, 06:41 AM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
Aqua Hot
Not sure if this should be in the "Technical" section or "Misc. Chit Chat", but here it goes...
Anyone know anything about these? Or know anyone who has used one?
http://www.aquahotoffroad.com/Pages/offroadheater.htm
I know its pretty much summer, but I just saw it and am actually thinking ahead hoping to not freeze my a** off again this winter.
I'm sure a drop curtain would help out my situation as well.
Old May 28th, 2010, 07:45 AM
That looks like a pretty good solution...
Old May 28th, 2010, 06:19 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Here is an install on a Heatercraft (known for quality installs on boats)
http://home.hiwaay.net/~sbuc/stalkerv6/heater.htm
Seems a bit more powerful and robust.
George Kase (sp?) also has a semi-write up under the build section of the forum. He put it in place of the original heater which I would also like to do.
My plan would be to bring 2" hose with splitters to feed the defrost, some front directed vents, and the footwells. Control would then be via turning the vents themselves on/off and modulating the fan.
Old May 29th, 2010, 07:36 AM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
For some reason it never crossed my mind to do a search on here for "heaters". Looks like there are multiple solutions out there besides the aquahot. The install of the Heatercraft looks pretty good and it seems like it would be a better solution since you can cut it up and move things around so the passenger and the driver would get some heat.
Old May 30th, 2010, 09:02 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Here is another hearer alternative that has been around for a while called the Moab heater , although I have never installed one I have read good things.
http://www.heatercraft.com/ProductIn...roductid=1101H
Chris "V"
Old May 30th, 2010, 05:21 PM
cdb
Clark Bowen
Chris...
I have the Moab heater in my Range Rover and while it puts out the heat, it is very noisy. I'd recommend looking at other brands/models.
2011 RR HSE -
2001 GMC 2500 4wd
Old May 31st, 2010, 03:18 PM
Chris Velardi
Chris Velardi
1975 101FC
"Moab heater in my Range Rover and while it puts out the heat, it is very noisy"
That's good to know , there is enough noise in a Defender with out any extra
Chris "V"
F-in hot down here milli Defender Technical Discussions 14 September 21st, 2005 08:21 AM
Hot wire somewhere waveridin1959 Defender Technical Discussions 1 September 18th, 2005 10:31 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
