Anyone who replaced the rear crossmember - Defender Source
Old October 10th, 2009, 07:49 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Any of you guys who have replaced the rear crossmember have photos of the job. The only rust on mine was on the cross and it was bad enough to use extensions. I'm about to get mine welded on and it would be helpful if anyone has any photos of how they did it.
The new cross has slightly different tabs....they are welded to the outside of the the member instead of turned under and welded on the top. It is the Roversnorth one they just started to carry again and was made for the 90. Im curious what you may have done with the plates with the circles cut out of them on each side of the tank, did you remove them from the old cm and weld on the new one.
R
Old October 10th, 2009, 09:20 AM
Cirbo's Avatar
Cirbo
Jim C.
Richard,
Ping me off line and I'll package and mail you some hi-res shots of the process when I did it.
Jim
seriesLR(at)gmail(d0t)com
Certified JB-Welder
ac
Rear crossmember and Bumper kennybahr Defender Technical Discussions 7 July 18th, 2008 10:57 PM
Rear Crossmember Repair mattarm Defender Technical Discussions 2 June 27th, 2006 07:07 AM
D-90 Rear crossmember neo812 Wanted 2 August 1st, 2004 02:29 PM
