anyone using their PTO for anything? - Defender Source
Old September 26th, 2008, 10:56 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I'd like to ask you some questions as to how it works, and so forth...
thanks
George
Old September 26th, 2008, 04:54 PM
LRover's Avatar
LRover
J. Michael McCaig
I have a rear pto on a series truck. I have used it to power a hay conveyor, pto generator, manure spreader and I have mowed a couple of times with it. For stationary use you put the transfercase in neutral and pick a transmission gear for the rpms and then set the engine speed to adjust rpms. pto turns fastest in 4th, slowest in 1st, it turns backwards in reverse and of course stops when you put in the clutch.
Old September 26th, 2008, 05:11 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
My winch is PTO driven. It's a Fairey PTO that came from the factory with it. It's ok but I would prefer a electric winch. I'm keeping just for nostalgia. It still pull great but is dead in the water if the engine dies.
Old September 26th, 2008, 05:21 PM
I will happily trade you your PTO winch for a warn electric.
Ron
Old September 26th, 2008, 05:41 PM
Gkase's Avatar
Gkase
George Kase
what I want to do is input an electric motor into the PTO area of the xfr case to run the defender via battery power...that's why I'm trying to get info on how that PTO input/output stuff works...any insights are welcome...
Old September 26th, 2008, 06:01 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Ron
If it wasn't such a PITA to take out I'd do it. It's surprising how many times I have used it. It ain't just sitting there looking pretty
Old September 26th, 2008, 09:35 PM
An EV? Please elaborate!
I could be wrong, but I'm guessing you'd need a way to engage the clutch in order to power it from the PTO (taking the engine out of the drivetrain). I'm not sure that the clutch diaphragm spring and throwout bearing would last long though.
Old September 26th, 2008, 10:03 PM
Gkase's Avatar
Gkase
George Kase
that's the knowledge I am looking for...is there a way to input power to PTO to rotate the drive train? what would happen if you just kept the trans in neutral while applying electric power to the PTO?
Old September 27th, 2008, 09:30 AM
Realy not sure. Sounds like LRover could confirm or deny this. Might very well work, as long as you don't mind having no gearing. It's my understanding that although an electric motor has great torque, if you want efficiency (which is the goal here), you need to run it at high rpms and I am not sure you can achieve that without gearing.
I'm very interested in this topic, although I'm currently of the opinion that a Defender is too heavy and doesn't have the aerodynamics to make it worth trying on.
charles
Old September 28th, 2008, 09:26 PM
LRover's Avatar
LRover
J. Michael McCaig
The PTO connects to the output of the transmission and could drive the tranfercase. When I mow with my series, the mower's centrifical force will actually push the vehicle at times and putting in the clutch does not help.
Pto Antichrist Defender Technical Discussions 26 April 24th, 2009 09:36 AM
Hydraulic PTO for sale 90/110 k4rovers For Sale - Parts 6 August 30th, 2006 07:31 PM
PTO Superwinch Setup for Defender or Series TDI Guy For Sale - Parts 6 May 1st, 2006 08:40 AM
PTO Cover seal Doug Defender Technical Discussions 2 October 29th, 2004 09:52 PM
Maxi-Drive Hydraulic PTO Info Hans Misc. Chit-Chat 2 February 19th, 2004 06:40 AM
