Anyone use a different idle air control valve (stepper motor)? - Defender Source
Old October 13th, 2009, 01:04 AM
Baja 90
Raul
97 D90, 94 RRC
Hi Guys,
I know there are a-lot of threads asking about putting in different stepper motors, or idle air control valves in 90's. I've read that the 80 Triumph Tr8's will fit, one thread sent me to a RR site that says the 87 Chevy Astro's will fit. I'm just worried I'll buy one and it won't work. Has anyone put one of these (or any other) on a 97 Defender? I need one, any ideas? Or do I have to fork up the $180, ouch! Thanks for your help!
Old October 13th, 2009, 01:17 AM
Buy a used one out of a 1996-99 DI from roverguy.com
Old October 13th, 2009, 02:13 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
OEM Part # AC-151. $35 or so from Autozone/Checkers. Straight cross for a 4.0 GEMS like you have in the 97.
Chances are that you may need to drop by the dealer and have the base idle re-set though as well if you put in a new one (genuine or otherwise). Sometimes the ECU will work it out, sometimes not.
Have you tried cleaning the one you have?
HTH
Ian
Old October 13th, 2009, 06:28 AM
Running a napa stepper with a number I got off range rovers.net with good results.
Old October 13th, 2009, 10:43 AM
61rover's Avatar
61rover
John Crouse
I installed the Chevy Astro equivilent from Autozone and have had zero problems.
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Running a GM part number in mine for about 6 months now with no problems (at least, no problems with THAT part)
My oil line fix
My 100k stopped odometer fix
Old October 13th, 2009, 11:19 AM
Baja 90
Raul
97 D90, 94 RRC
HTH
Ian
I have tried cleaning it, idle is still going crazy. Sometimes high, sometimes low, sometimes just fine. Ian, you got me thinking, I have a battery cuttoff switch that I turn on and off often. Do you guys think that may have messed with the ECU? Maybe I just have the base idle re-set and go from there?
Thanks for your help guys, wish I could buy everybody a few rounds!
Old October 13th, 2009, 07:32 PM
Defenderbuser's Avatar
Defenderbuser
Chuck Duncan
1994 D90 Softop
I've had good luck with the $35 Advance Auto Astro Van part.
Old October 14th, 2009, 03:08 PM
texmoto
david summers
99 Discovery II
Ditto on the GM part, on my '94 90. Runs fine with no idle adjustment.
Old October 16th, 2009, 12:18 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
He says he has a 97 which has a unique set up and IACV compared to that on the 3.9s fitted in previous years. The 3.9 is fitted to the rear of the plenum chamber, the 4.0 is next to the TPS on the throttle body.
Baja 90. Yes your symptoms are exactly those of requiring the base idle to be reset. Your ECU has lost touch with the motor and has been unable to resync properly (it doesn't know where the plunger is and has been unable to work it out on it's own). I am not sure if it is because of your Ground cut off though.
It will take about 20 mins at a dealer and cost you your 1st born...
I would suggest checking over your Vacuum hoses as well to make sure you don't have any leaks.
Old October 16th, 2009, 12:21 AM
I would not use a battery cut off on a GEMS truck.
Old October 16th, 2009, 01:15 AM
Baja 90
Raul
97 D90, 94 RRC
Thanks for all your help guys. I was talking to some friends and they suggested to drive for a while to give the computer some time to re-set. Hopefully that works. Won't be using the cutoff switch anytime soon! Thanks for taking the time, I'll keep you posted.
Old October 16th, 2009, 01:21 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
When I replaced my batteries a while back, it took a little while for the ecu to relearn idle and the truck would idle high and low until it did. I wouldn't put a battery cut off in my 95 Def.
idle, motor
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Stepper Motor- idle air control 1995 Scott 9835 Defender Technical Discussions 3 October 23rd, 2006 02:20 PM
Clunk - Die milli Defender Technical Discussions 62 October 7th, 2005 07:27 PM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
