Anyone shear an O2 Sensor - Defender Source
Old May 24th, 2004, 11:22 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
This was one fun weekend. In addition to my A/C woes, I found a new coolant leak, then my driver's side O2 sensor sheared off while attempting to remove and replace it. I sprayed some thread loosener, let it soak for a while, then proceeded. It seemed to be loosening okay, but when removed, the threads and lower section remained.
Besides cutting and reinstalling the section between the manifold and cat, does anyone have any suggestions? Access to this sensor is limited, and I can't imagine it do any good to risk pieces parts falling into the cat.
"Uhh...I think they all leak like that."
Old May 24th, 2004, 11:29 AM
OH man, all that I can say is to throw some high temp anti seize on the new one. I agree drilling could be bad if parts fall into the Cat. If you can't grab it with some Visegrips then you may be in trouble.
Old May 24th, 2004, 08:37 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
IF you drill!! Use vaseline on the drill bit! It will help with the shavings! Use plenty & clean then reapply!
sensor
O2 Sensor troubleshoot floatflyer Defender Technical Discussions 2 November 7th, 2009 09:34 PM
O2 Sensor Removal w/ LRT-12-047 pcscharfe Defender Technical Discussions 9 November 13th, 2008 12:30 PM
O2 Sensor Longevity... norros Defender Technical Discussions 30 October 22nd, 2007 11:51 PM
Help w/ O2 sensor... mspell Defender Technical Discussions 5 January 7th, 2005 09:20 AM
