Anyone running 285/75r16's? - Page 2 - Defender Source
Old March 19th, 2009, 11:24 AM
Ummm, just adjust the steering stops to get rid of radius arm rubbing....
Old March 19th, 2009, 11:37 AM
Cube II's Avatar
Cube II
Michele
1997 D90
My steering stop bolts ran out of thread
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 19th, 2009, 11:46 AM
One of mine is bent. and I figured I get better turning radius with it rubbing anyway
Old March 19th, 2009, 05:52 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
I am a fan of the 285/75/16.
Here's a couple more pics with BFG Mud terrians.
ID:	18350   Click image for larger version
Old March 19th, 2009, 06:37 PM
cabell's Avatar
cabell
Cabell Crowther
Paul, what spring set have you got on the biege truck? It looks great!
Old March 19th, 2009, 08:38 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Even easier if while you are doing the fronts you fit a set of tubular dual shock towers (depending on road salt etc you may need some anyway) and install the shocks on the outboard mounts. This makes changing either much easier in the future.
Old March 20th, 2009, 11:52 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Soft top has Old Man Emu 766
The green SW has Rovertym springs
Old March 20th, 2009, 02:12 PM
hamiamham
mike
97 D-90
im considering the same upgrade for my truck; ie to goto the 285/75R16. Mine is an island car and Im primarily concerned about performance on beach sand. Ive found my mud terrain tires arent good on sand. any suggestions for brand and model of tire for my aplication?
Old March 20th, 2009, 06:14 PM
my BFG MT's do fine in the sand, Ive never aired them down.
Old March 20th, 2009, 07:39 PM
Sand is all about air pressure, nothing else.
Old March 21st, 2009, 03:48 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Just upgraded to KM2's. Will run in NVTR next month and report. I'm on AMR wheels 4.5 inch backspace, with 1 inch spacers added. (See avatar photo)
Old March 22nd, 2009, 08:18 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I have the BFG AT/ko on my TD5 D90 ST in the 285/75-R16 flavor...stock 16" allows, (castor), 1.25" spacers, stock suspension and sway bars...a little rubbing on the eye-brows when fully flexed (which isn't much given the sway bars)
IMHO, these trucks should have come stock with this tire size...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old March 22nd, 2009, 09:56 PM
Santiago
Santiago Gigola
I had 285/75/16 BFG ATīs in my Defender 110. Great tires and look awesome but at least in my experience on the D110 you must forget about using snow chains over these tires because the chains touch against the springs in the back (and maybe in the front too). This is more complicated than the odd tire rubbing here and there. Maybe in the D90 it is different.
I had the 285īs installed on American Racing 7 inch wide alloy rims which had a different backspaing than stock rims and allowed to turn fine but it was not enough for the chains.
I now have BFG 265/75/16 MT and in sand there are just fine! just give em 12 psi
cheers
santiago
here goes a pic of the 265/75/16 BFG MT in very soft sand and with just 10 psi. worked fine.
Old March 22nd, 2009, 10:25 PM
hamiamham
mike
97 D-90
sorry; not familiar with the terms. if i upgrade to 285/75R16 will I need "spacers" or anything else. If so, where can one buy them?
Old March 22nd, 2009, 10:49 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Rovers north has em.
Old March 23rd, 2009, 12:54 PM
hamiamham
mike
97 D-90
thanks
Old March 26th, 2009, 01:58 PM
wadaman
Glenn Wada
97 D-90 #1257
So what comes first spacers or new springs?
Will be picking up some 285/75/16's this weekend. Won't be doing any off roading soon. Should I but spacers first or are new springs a better near term purchase? Thanks.
Old March 26th, 2009, 02:05 PM
Springs and shocks. You may never need spacers - most of us don't run them.
charles
Old March 26th, 2009, 02:06 PM
you can run the 285's stock. springs.
Old May 13th, 2009, 02:06 PM
specops1526's Avatar
specops1526
Beluga '97 90
Will the extra weight and size (if it's even that much at all) of the 285s strain the driveline any? I know the speedometer will be off by a little but that's not a big deal. just trying to decide on 265 KM2s or 285s.
My truck is completely stock.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Running Rich Please Help bstraw Defender Technical Discussions 23 October 26th, 2007 10:44 AM
2 Sets of Running Boards steved90 For Sale - Parts 10 March 2nd, 2006 02:28 PM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
It's Running! Mike Hippert Misc. Chit-Chat 26 June 2nd, 2005 08:04 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
