Anyone out there know of a Tri-Y Headers for a Defender? - Defender Source
Old October 28th, 2010, 02:41 PM
DefenderPilot
George
1997 D90 SW
Hello to the members. Im a new Defender owner and would have been searching for upgrades and would love to have a Try-Y header which will be great for this type of engine. Any members using one or know of any good ones out there? Thanks regards George
Old October 29th, 2010, 09:24 PM
jack SF
jack baran
95 ST yellow
I'm pretty sure there is no headers for the defender.
Has any tried to install the headers/manifolds of a range rover p38 onto a d90?
Old October 30th, 2010, 12:07 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I tried the Range Rover headers that are listed on summitracing and decided that they'd be too much work to make them fit. I ended up going with the block hugger headers from Aluminum V8: http://www.aluminumv8.com/catalogpages/headers.htm
They were a much closer fit than the Hedman's from Summit but they still needed a bit of tweaking to get around the passenger side engine mount properly. The driver's side one also causes the need for some pipework to make sure you have enough room for the oil pan drain plug to clear (need to route the pipe towards the frame rail a bit and then back so it's not too close to the drain plug. All-in-all, I'd do the block huggers again though. I had some slight trouble getting them to seal to the block as well, but finally got it. Now the exhaust sounds great! After the headers, I used two universal 2.5" high flow cats that came back into a y-pipe similar to stock, then a 3" pipe and muffler out the back. Gives a nice deep sound and free-er feel to the engine revs.
Old October 30th, 2010, 06:30 PM
DefenderPilot
George
1997 D90 SW
Darn it all! Im surprised no one makes a bolt on Tri-Y. The low and mid range gain would much better.
There were no pictures for the block hugers. Do they have o2 bungs?
These were the only ones I know of but they are 4-1 headers.
http://www.toddcosuspensions.com/larode90110h.html
Old October 30th, 2010, 07:05 PM
cbass's Avatar
cbass
Bradlee Duncan
Interesting.. those look almost exactly like the Hedman's from Summit. You should call and ask them if they bolt right up or if they need modification for a LHD d-90.
The block huggers do not have bungs in them.
Old October 31st, 2010, 10:56 AM
Do a web search for Buick 300 headers and you'll find many options
Old October 31st, 2010, 09:45 PM
DefenderPilot
George
1997 D90 SW
These aren't the headmen. From what I read, they are thicker and of a much better quality plus they have O2 fittings and are made to bolt to NAS Defenders. The problem is that they are 4-1 which is not good for and engine that redlines at 5500RPM. Good Tri-y type headers will make a nice improvement up to 5500 RPM
------ Follow up post added October 31st, 2010 06:48 PM ------
I looked just now and they all seemed to be made to fit MG cars? I need it to fit a Defender and have an o2 sensor bung. I guess I can put the bung if need be but fitting correctly is the most important thing.
Old November 1st, 2010, 08:33 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
here is a set from the UK
http://cgi.ebay.co.uk/ROVER-V8-JANSP...item3a5e5ede19
Old November 2nd, 2010, 02:50 AM
DefenderPilot
George
1997 D90 SW
Originally Posted by jetmech View Post
Wow thanks Janspeed. Ill have to find them and email them.
Old November 6th, 2010, 04:35 AM
DefenderPilot
George
1997 D90 SW
Thanks for everyone help. I still would like to find other Tri-y headers? The Janspeed needs a cat pipe kit and they are in the UK so its expressive to ship. Anyothers??
Old November 8th, 2010, 11:54 AM
I read this as "I want to add performance parts to my engine but don't want to spend the money it takes to do so"
Old November 8th, 2010, 12:32 PM
DefenderPilot
George
1997 D90 SW
No quite, its more like " I wonder what else is out there. Are there better headers that someone makes in the US or any others out there to chose from? These Japspeeds also needs there cat pipe kit and would that pass US smog checks?" hehe
header
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
