Anyone mod their A/C? - Page 2 - Defender Source
Old August 6th, 2011, 10:44 PM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Stock 4.2 compressor
Classic Auto Air electronic streetrod unit
Vents, condensor, all came from Classic. Black anodized control panel
I had to modify the unit as it came from Classic by moving the squirrel cage from one end to the other. No biggie, but the rest of the install was pretty intense. The unit had to be recessed half in/out of the pass side footwell top which is at an angle.It is designed to only have recirc air hence the half in/out scenario. Shot of the condenser behind the tranny cooler.
1963/2008 Defender Crew Cab
1965/1997 FJ45 Pick up
Old August 7th, 2011, 01:21 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
wow...nice work.
Old November 11th, 2011, 12:52 PM
RickM
Rick Mabus
95 D-90 ST
You guys doing these HVAC conversions, how do these systems work as far as power drain on the engine.
I don't use my current under dash HVAC as it pulls to much on the engine under power and makes for sluggish driving.
Old November 11th, 2011, 02:28 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Rick,
You must have something wrong. I can tell a slight reduction in power with mine on but not to the point I would turn it off. Especially in Dallas in August.
In my SW this summer, it couldnt keep up with the heat. I am all ears for more cooling ideas.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
mod
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
Rear A/C m.michaels Defender Technical Discussions 1 October 8th, 2005 02:15 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
