Anyone make their own cages? - Defender Source
Old December 21st, 2012, 10:40 AM
gomotomoto
adam
Just curious if anyone here has fabricated their own cages. I'm thinking of doing up my own. I can TIG weld steel without issue but still working on my aluminum skills. Might be a cool project for my new 110 doublecab.
Old December 21st, 2012, 10:49 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I do a lot of cages for off road and racing, but when it came time to build a cage for my 110 I went with a Safety Devices cage. I did the math on the labor and time involved to build mine, and I was almost a tie. Rovers are not as easy as most car and trucks. Limited interior space, frame placement, and a weak bulkhead are key contributors.
But if you are up for the adventure, go for it! Do you have a tubing bender?
Semper Fi!
Old December 21st, 2012, 10:57 AM
I have seen a few custom cages to replace the ST Cage for hard core off road or complete the cage with a fast back...
Old December 21st, 2012, 11:14 AM
gomotomoto
adam
3k installed I thought I could give it a go on my own but after hearing its a wash...
Do these ever surface up used? I know the truck already has unicorn status...
Old December 21st, 2012, 11:32 AM
If by used, you mean parted out from junk trucks, then yes, they do. But you'll almost never see them for sale anywhere (you don't just look on ebay for "used defender cage" ) - they merely change hands.
In the words of ECR - these things once put on trucks are never taken off.
If your real question is, "How do I get a full exocage for my truck that costs $500" then you'll have to get in line, sorry.
Old December 21st, 2012, 12:00 PM
gomotomoto
adam
Yes I understand that this can't be had for 500. That would be ridiculous. But in the scheme of things 3k installed is definitely not good value or accurately priced compared to other fabrications that are similar.
Am I the only one that thinks they are overpriced? Once the jigs are set up I can't imagine it being too difficult.
Fabricators that work on boat t-tops and towers could probably make this up for about half. Ill pursue that route first.
Old December 21st, 2012, 12:20 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Do you want a quality cage to keep rocks and trees off your head or do you just want to keep the rain and sun off your head.
WolfFab pretty much nailed it. It takes time and skill to do it right. Unless you have a friend with the right skills who is willing to work for cheap, it's going to cost you a bit to do it right. I'd estimate over $500 in materials alone for the cage on my 109.
Old December 21st, 2012, 12:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
No fabricator besides P&P and SD have jigs for Rover cages. There is very little demand here in the US to compete with SD, let alone the justification to make jigs.
I don't think the cages are overpriced, even if they have jigs. They are generally cheaper than what it would cost me to build in my shop, which is why I usually turn away Rover cage requests.
Semper Fi!
Old December 21st, 2012, 12:38 PM
As Jonathan says, the added cost is in lack of demand.
Another thing - there is a huge cost associated with the cage feet, the cage to frame supports and brackets. Attempting to fabricate these components is difficult - especially the cage feet, which are radiused plates that match the curvature of the body panels.
I wish it were just bent hoops, notched tubes and some mig welds.
By the way, if $3k is too much, then look into P&P's cages. They should come in at under $2k for the cage only.
Old December 21st, 2012, 12:48 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
I did my own after daughter rolled original cage and say go for it if you have the time and interest. You'll notice the stock cages are not of the best type of steel anyhow and recommend D.O.M or chromoly if afford. I changed the style so can walk through w top off but still install cross bar for original soft top to fit. I used stock mounting points so can be unbolted from body but didn't make the cage unbolt able in 15 places like original.
It was fun if you have the time and interest.
Old December 21st, 2012, 03:26 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
landen nicely done
Old December 21st, 2012, 03:40 PM
d110pickup
Mike Pado
'97 D90 ST #1153
Landen,
That is a nice looking cage, will you poat a few morw photos?
Old December 21st, 2012, 04:25 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
There are a few here:
http://www.defendersource.com/forum/...ad.php?t=41733
Old December 21st, 2012, 04:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
If you want to simplify, then go for a full exo-cage mounted onto H/D rock sliders. That'll make things allot easier as you won't need as many custom brackets for the front 'A' post legs etc.
When I lived in the UK, I got the curved tub top plates from these guys.... http://www.tomcatmotorsport.co.uk/
Not sure of they still sell them though, was 6yrs ago. P&P sell the cage connector brackets on their Ebay site here http://www.ebay.co.uk/itm/Roll-Cage-...item2303caea10
Invest in a copy of Bend-Tech Pro V6, it'll save you money in the long run... you could always sell the tube cutting plans to cover the costs ;~)
Have fun !
BTW, pic's of my cage in my build thread here http://www.defendersource.com/forum/...ad.php?t=36827
Old December 21st, 2012, 04:48 PM
Andy, do you know anyone who makes those in North America or currently in the UK?
Old December 21st, 2012, 06:19 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Hard take pics of cage when on truck but here's a couple more. Couple soapbox comments with cages. Although recommend trying ones self or with friends, make sure you have someone w experience either building race cages or even decent welder on your welds if at all uncertain of you workmanship. If one does buy aftermarket think of your cage like a motorcycle helmet, I wouldn't buy cheapest one I could find.
Off the soapbox and a couple more shots. Again have fun mixing it up. This will fit stock soft top and hopefully Badger if can get one.
The top hoop bar is the stock one for soft top and "plugs in" like stock. Someone inquired on remaining stock bars. Most are bent but will sift through and see if any "worth saving" again a little nervous on any "tested" roll cage parts as they could have been compromised when rolled.
Old December 21st, 2012, 08:01 PM
Landy_Andy's Avatar
Landy_Andy
Andy
P&P make them for their cages, if you give them a call they might sell you some along with the cage joints... worth a try. Try Tomcat too.
You could just buy a P&P cage kit... they do a 130 double cab already, a 110 should be no problem http://www.ppcages.com/?page_id=106&pid=342#WPshowroom
Shipping would prob be a bit $$ but one option is to try the UK Ex-pats web forum. You might finds someone emigrating in the new year that's bringing a container stateside.... hint hint
Old December 21st, 2012, 09:55 PM
ron's Avatar
ron
Ron
form and funtion nice
Old December 21st, 2012, 11:31 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
That is good lookin work.
Old December 22nd, 2012, 07:12 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have press dies for the SD type connections and the cage feet. I think they are on Overland Engineering FB page under "mudbug"(sorry I'd link it but am pretty useless with a phone lol). Could probably crush some if there was any demand.
I make cages too but only in house and not cheap. All DOM and all built to crash.
Matt Browne
cage
Safety Devices Crew Cab & SW Roll Cages Now Available SafariHP The Vendors Loft 10 August 19th, 2010 06:58 AM
Make me an offer! taydt For Sale - Parts 2 February 14th, 2010 04:42 PM
D90 stock aluminum wheels for sale: make offer Steve Friedman For Sale - Parts 1 December 31st, 2006 01:26 AM
does anyone make a selectable hubs for a rover TDI Guy Misc. Chit-Chat 17 June 16th, 2006 05:52 PM
How to make my jpeg into a thumbnail? Chris Cox Support & Suggestions 6 October 2nd, 2003 07:18 PM
