Anyone know what this leak is on a 4.0 GEMS V8? - Defender Source
Old June 6th, 2014, 08:59 PM
svxaddict
Defend Nature
coming soon
power steering fluid? looks to have been patched up on something?
Name:	Screen Shot 2014-06-06 at 8.53.01 PM copy.jpg
ID:	96373   Click image for larger version
Name:	Screen Shot 2014-06-06 at 8.54.53 PM copy.jpg
Old June 6th, 2014, 09:05 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
The green stuff is coolant.
Old June 6th, 2014, 09:08 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Front cover gasket
Old June 6th, 2014, 09:14 PM
svxaddict
Defend Nature
coming soon
Coolant isn't pinkish on these? Strange! (new clueless owner, can you tell?) Assuming the front cover gasket is a common issue, estimated cost of repair in the pacific NW?
Old June 6th, 2014, 09:24 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
The front cover gasket is about $10 and most shops charge 4.5 hrs to reseal it. Some RTV for the oil pan, new coolant oil and filter and your good to go.
Old June 6th, 2014, 09:25 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
I wouldn't assume it's a front cover gasket. That first picture can be leak trickling down from a bunch of places. I can't tell where that second one is and what the Ghostbuster slime is.
I chased for 8 mo a coolant leak to find out my brass reserve tank was leaking.
Check the easy stuff first... hoses, cracks etc. Then if you really have to drain the fluid, change out as much as you want/can.
Old June 7th, 2014, 07:20 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Pressure test the cooling system, Napa makes a nice test pump. Just don't go over 15 psi. Pump it up and you'll find the leak. You can also use this pump ( the one with the inflatable Blatter) in the small radiator opening to test your radiator cap and overflow tank.
Old June 7th, 2014, 07:25 PM
x2 you can rent this from autozone for free ... you leave a deposit which they refund when you take it back. The pump is worth more than the deposit ... so i kept mine.
This will help force coolant out if you have a leak and you should easily be able to trace it.
Old June 7th, 2014, 10:02 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I always assume "Ghostbuster" slime is coolant/oil mix. Could mean bad things....
Old June 7th, 2014, 10:05 PM
Based on the second picture, I would guess the intake gasket, not the front cover gasket. What is that gunk in the second picture?
v8
Rim choices (I know I know dead horse being beat) El Solis Defender Technical Discussions 7 August 18th, 2013 10:14 PM
defender 90 roll cage - i know i know d90boy Wanted 10 April 28th, 2011 06:58 PM
WTB: 4.6 short block GEMS fleabus Wanted 0 March 23rd, 2008 04:30 PM
97 D-90 Gems Ecu Engine Management JPRO576 For Sale - Parts 1 January 21st, 2008 07:17 PM
GEMS or Bosch boxerhips Defender Technical Discussions 34 January 5th, 2006 05:25 PM
