Anyone know the thread size on a 200Tdi coolant temp sender? - Defender Source
Old June 23rd, 2010, 05:57 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Also, how about a Series III temp sender? I'm trying to work out how to accurately (loose term) monitor my ect of my 200tdi, using my original SIII dash.. I've heard there is a brass adapter on the 2.5L that screws into the coolant port, and the internal thread matches that of the S3 sender... I'm hesitant to call RN, as I'm sure it will be spendy. I'm thinking Mcmaster probably has what I need for a little less.
Any Ideas? Anyone know the ohms range for any of these senders?
Thanks!
Old June 23rd, 2010, 07:12 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Dont know the size but the 200tdi VDO sender is 323-026.
At least that is what threaded in to Tony (Kpsi16) screwed into his 200.
Old June 24th, 2010, 11:03 AM
Defender or Disco 200TDI? I believe they are different.
Defender 200TDI is 5/8" NF.
Old June 24th, 2010, 12:02 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
Dang Steve, took me 10 minutes to find my receipt
Yes, it's a Defender 200TDI. VDO sender 323-026 screwed right in with as a 5/8-18 NPT
Old June 24th, 2010, 03:35 PM
D90user's Avatar
D90user
steve
I have a photographic memory... just kidding I happen to take a picture of the package on my phone for a buddy
Old June 24th, 2010, 10:47 PM
Turbofan's Avatar
Turbofan
Ethan
Thanks.. Are you using an aftermarket CFO gauge, or a d90 cluster?
------ Follow up post added June 24th, 2010 10:51 PM ------
And on a random note, how much is a d90 fiberglass hardtop worth in"good" not perfect condition? I'm working on a trade...
Old June 25th, 2010, 12:17 AM
5/8-18 NPT
NF not NPT Big difference.
Old June 25th, 2010, 01:07 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Good Grief, you're right John. NF NOT npt
200tdi, coolant, tdi
disco 200tdi temp sender D90user Defender Technical Discussions 2 February 1st, 2008 09:18 AM
Temp Sender Thread Size for NAS110 surf110 Defender Technical Discussions 2 August 18th, 2006 09:36 PM
Temperature sender thread type/pitch? Neo Defender Technical Discussions 4 March 9th, 2006 02:40 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
