anyone know a welder/fabricator for NAS to POE? - Defender Source
Old July 19th, 2007, 05:24 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I am putting the finishing touches on my NAS soft top to NAS POE conversion and want to see if I can make two critical parts available so others can do this too. As it turns out, a Rest Of World hardtop will fit easily on an NAS soft top but the front external roll cage needs two short pieces so that the longitudinal tubes above the windows will have the ending pieces that bolt to the hard top. I am making a CAD drawing and want to have someone make these pieces so I can try them out to make sure I did the drawing right and then, if there's interest, post the info and CAD drawing to the appropiate section of this site...like I said, if there's interest.
So, anyone know a fabricator?
George
Old July 19th, 2007, 06:46 PM
Hey George - are you just "flexing" the NAS hoop to attach it to the roof sides? And D90 hardtop fill fit, and I just drilled the one I got for the roll cage attachment. I thought about how to attach the hoop to the roof sides and in the end just sourced out a NAS SW roll cage so that it would fit properly and have the internal cage to support it. I wasnt super-fond of the POE roll-cage-bolted-to-top set-up. I talked to Roverhybrids back when I was considering what to do, and it ended up being cheaper to buy the NAS cage than to fab an interior cage and make extensions for the roll hoop.
This sort of thing sounds like its right up Jim Cirbus's alley though.
Old July 20th, 2007, 12:26 PM
Gkase's Avatar
Gkase
George Kase
Hi Jim,
There isn't any flexing of the front hoop involved. It just needs the two new "ends" to bolt them to the top. I used to have a real POE and didn't mind not having the internal roll bar. the SW roll bar I purchased was a piece of junk and was bent so I couldn't use it, but I don't mind. Hell, the rest of the world doesn't have roll bars inside, why should I? anyway, the usefulness of the liftgate for hauling long pieces of lumber and so on is what motivated me to go ahead with this. I assume you bought the SW cage used? what did you pay for it?
Old July 20th, 2007, 03:26 PM
I got the cage complete for 1000, obviously used. Obviously much more expensive when bought as separate pieces from LR.
All the POE's I've seen (only in pix) have the roll hoop tilted forward slightly because the horizonal rail on the SW is an inch higher than on the ST part. I didnt dig that look.
Old July 20th, 2007, 03:39 PM
Gkase's Avatar
Gkase
George Kase
no need to tilt the roll cage at all from what I can tell...when I get a chance I'll post a pic.
Old July 20th, 2007, 03:52 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jim is right. The horizontal bars over the door on a st are lower then that of a SW. Therfore, the POE cage is a ST cage and the horizontal bars over the doors are on an angle up in the rear to kind of match up with the roof and so as not to hit the roof drip channel. I know this cause I have a ST cage on my truck and a ROW hard top. You can sweak it up to work like LR did for the few POE's but I would look into the other option for sure and sell the ST front hoop. At least get a SW front hoop. IT would then fit perfectly onto the roof...
Legend in My Own Mind.
Old July 20th, 2007, 04:00 PM
Gkase's Avatar
Gkase
George Kase
My soft top front cage fits on my euro hardtop with no angles involved...like I said, I'll post a pic this weekend.
Old July 24th, 2007, 03:12 PM
Gkase's Avatar
Gkase
George Kase
here's the pix
I haven't drilled the bolt holes to permanently mount these roll bar ends, but here they are "dry fitted" in place...see, no bending of the front roll cage needed! anyway, these are the parts I want to see if I can have fabricated.
ID:	9867   Click image for larger version
Old July 24th, 2007, 03:49 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
From the photos your cage appears to fit the same way the one on my 94 POE does. Best of luck with the install.
Old July 24th, 2007, 05:28 PM
Grover's Avatar
Grover
If you haven't drilled the holes in the top yet, why not run the roll cage tube along the length of the roof and use it to attach a roof rack. I have seen in done in Land Rover mags.
Cheers...
Old July 24th, 2007, 06:12 PM
I would be interested in a set of two of the POE brackets if you get them made. I am sure there is a market. Did you call mike at west chester to see if he can get them?
Ron
Old July 24th, 2007, 07:55 PM
Gkase's Avatar
Gkase
George Kase
these short POE brackets don't exist as far as I have been able to find...I cut down a pair of SW tubes...
Grover...that is a really interesting idea...hmmmm....
Old July 24th, 2007, 08:53 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
My '94 ST converted to a ROW hard top has the tilted side bars. I wish they were straight, it would look a lot better.
Gary
Old July 25th, 2007, 11:55 AM
Gkase's Avatar
Gkase
George Kase
So, does anyone know who might fabricate these parts from a CAD drawing?
Old July 25th, 2007, 05:28 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Bring your cads to a steel detailing shop and talk to them about having them fab it for you. If you were here in FL I could recommend a few places. I'm having my rear tire carrier remade by a local steel fabricator. Cheaper to have one bent and welded up from the example than to buy a new one from LR or any other source. Figure I'll lay a number of coats of rust resisting paint or bed liner on it and it's good as new.
Btw Krylon Rust Tough Enamel paint flat black matches the existing powder coat pretty well but you'll probably just want to spray the whole thing to make it look uniform and I'm sure there is some rust you'll want to clean from some spots.
S-P
Old July 25th, 2007, 05:57 PM
Gkase's Avatar
Gkase
George Kase
S-P,
What is the generic name for such a shop, like what would the yellow pages file them under?
Old July 25th, 2007, 06:31 PM
cdb
Clark Bowen
What size tires are those?
Gary..
I was looking at your POE rollcage bars picture and saw that your tires absolutely fill the rear wheel well and I was curious what size are they.
Apologies for tangenting off this thread.
Clark
Old July 26th, 2007, 11:34 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
From your pics George, you can see that the bar above the window is a st bar. If someone with a SW took a pic, it would be a few inches higher and sit even with the drip rail. The bar that loops around the window is whats different. If you were to keep this setup, I would have a cage guy lenghten the uprights on the windscreen hoop and then adjust the side bars and re weld them. You just need the measurements from a SW. IT looks much better.. Anyone that does cages can handle this type of job.
Old July 26th, 2007, 11:40 AM
Gkase's Avatar
Gkase
George Kase
Thanks Randy for the further info on the diff between the ST and SW...however, I must say I don't mind the way this looks...that being said, does anyone know of a "cage guy" in the midwest? I don't have a clue how to find a shop like that...I know there must be several in the Chicago area, but I just don't know how to find em...help anyone?
Old July 27th, 2007, 08:38 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Sorry for not getting back to ya sooner. If you look under welders in the phone book you should find some places that will do the fab work. It may take a little calling around but you'll get one. Also if you google chicago welding shops you'll get a plethora of shops.
best of luck
S-P
nas
1994 (POE) Defender for sale 1 of 40 stanman For Sale - Vehicles 11 September 12th, 2007 06:28 PM
'94 POE SW questions tbmcneill Defender Technical Discussions 5 May 9th, 2005 11:09 AM
Length of gas struts for POE liftgate? Chris Cox Defender Technical Discussions 5 October 15th, 2004 02:39 PM
Pics of POE please Chris Cox Defender Technical Discussions 2 August 3rd, 2004 02:27 PM
Questions about '94 POE Art Vigil Misc. Chit-Chat 14 June 21st, 2004 01:49 AM
